Old 08-28-2015, 10:09 AM   #1
Does anyone know what this would be?
We have a MicroLite 23LB, which is the sister camper of the Rockwood 2306. This trim piece runs alongside the bed on one side from the front of the camper to the kitchen cabinets where the furnace and sink are. Click image for larger version
Name:	ImageUploadedByForest River Forums1440774519.114409.jpg
ID:	87138Click image for larger version
Name:	ImageUploadedByForest River Forums1440774540.095955.jpg
ID:	87139Just wondering what could be inside of it. We were wanting to put hooks in it and attach a bungee cord to hold our trash can in place when traveling but we sure don't want to drill into a pipe or something. Any ideas?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 08-28-2015, 10:29 AM   #2
rsdata's Avatar
Use 3M Command hooks, no drilling and you can reposition when you want to or 1/2" screws should only poke through maybe 1/4" or less
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-28-2015, 10:40 AM   #3
EastlakeRoo's Avatar
2nd the 3M Command Hooks. I'm sure there are wires in the wood casing and would be hesitant to send a drill bit thru the wood. I'm err on caution and use the command hooks like rsdata suggested.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 08-28-2015, 11:17 AM   #4
Excellent idea about the Command hooks but just wondering if they would hold up under the pressure of pulling the bungee cord tight around the trash can.
2011 MicroLite 23LB
Old 08-28-2015, 11:35 AM   #5
V-Lite Fun's Avatar
I use the Command hooks to hold up our laundry bag. It gets pretty heavy and has never fallen down. Should hold a bungee if it isn't as tight as a banjo string.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
Old 08-28-2015, 11:57 AM   #6
I have a 2016 23LB but mine doesn't have that.
I will 2nd the 3M command hooks. I have several of the 3M command products. I used the picture hanging kit (like velcro on steroids) to hang a cheap full length mirror on the bathroom door and to hold the paper towel holder on the bottom of the cabinets. Several of the hooks on the wall for shirts, jackets and hats.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-28-2015, 01:09 PM   #7
PSUFan1's Avatar
We have a 2012 micro lite 23 lb and I would guess the casing is carrying either electrical and/or water pipes. Our hot water heater is directly under the bed in the front storage. I agree with everyone else I wouldn't drill a hole.
We put our trash can under the sink. Obviously a small trash can that holds a day or two of trash. Any longer than that and we have ants.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 08-28-2015, 01:12 PM   #8
PSUFan1's Avatar
The 2016 models have the hot water heater under the bunk beds which leads me to believe that the casing is carrying the water pipes.
Old 08-28-2015, 01:16 PM   #9
That trim piece has the water hoses in it. I wouldn't drill any holes in it. We have the same trim piece in the bedroom under the closet slide. Fresh water tank, hot water heater, and water pump at the end of hoses in the basement under the bed.
Momma Tac is offline   Reply With Quote
Old 08-28-2015, 01:18 PM   #10
Mine does not have this either. There is nothing under the couch or bed other than the wires for the marker lights and those run under the trailer. Mine has the Murphy bed so maybe the fixed bed has something under it.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
