Old 04-15-2017, 03:39 PM   #1
frankm's Avatar
Dometic DMR702 Fridge - No Power
Our Dometic DMR702 fridge quit working overnight, none of the fridge's panel or internal light were operational, completely dead. We are on campground power, trailer battery reads 13.45v. All other 12v lights are working fine, internal fuse panel all ok too.
After a bit of troubleshooting I found the issue to be the 12v thermal fuse (see diagram, item H). It is a 152°C fuse with a part number of DF152s (see pic, sorry for the blur). If I bypass it the fridge works and cools perfectly, so here is where I am:
- What caused it to blow? Many theories online including an obstructed vent or burner to just simply a fuse gone bad.
Any other ideas or causes that I can check?
- Read a few posts (not here) about this thermal fuse was part of a Dometic recall dealing with potential issues when running on propane.
Since I'm not running propane can I bypass this safely until I get a replacement fuse?
Thanks for your replies.
PS. Tried posting this question in the Gen Discussion- Appliances section however I'm told I have no rights to that section. [emoji46]
ID:	134817Click image for larger version
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 04-15-2017, 04:17 PM   #2
In my experience with appliances a thermal fuse will blow when a certain temperature is exceeded and then must be replaced. This is a safety for excessive temperatures. Probably just a bad thermal fuse. I'd replace it and see how it goes. Simple enough to do.
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
Handydc is offline   Reply With Quote
Old 04-16-2017, 08:03 AM   #3
frankm's Avatar
Thanks handydc, already ordered the fuse. I was trying to get ahead with info in the event it blows right after I replace it.
Frank & Rita M
Old 04-17-2017, 07:08 PM   #4
Herowe's Avatar
Same Problem
Came home from the first weekend out. Same thing. Unloading had no lights on fridge.
DMR702 in 2017 Rockwood Ultra Lite 2902WS
Fuse in distribution box was good, but no 12V in distribution box.
Traced 12V in back to same blown thermistor.
I want to replace it. DW wants me to call the dealer. It's brand new picked it up about a month ago. Dealer is only 14 miles away.
Let me know if you have an update frankm.
Herowe is offline   Reply With Quote
Old 04-17-2017, 07:22 PM   #5
frankm's Avatar
In my case it wasn't the thermistor (C) but the thermal fuse (H). Ordered the fuse and will replace once, if it blows again then taking it in. I'm also under the warranty but dealer is a couple of hours drive.
Frank & Rita M
Old 04-17-2017, 07:28 PM   #6
Herowe's Avatar
Hi frankm
Sorry I should have said thermal fuse. It is the same one. DF152s
I'll call dealer tomorrow. But order a couple for the road.
Old 04-17-2017, 07:32 PM   #7
frankm's Avatar
Amazon has a pack of 10 for $12, free shipping with Prime.
Frank & Rita M
Old 04-17-2017, 07:34 PM   #8
frankm's Avatar
Also please let me know what dealer says as to what the cause was or may have been.
Frank & Rita M
Old 04-18-2017, 01:58 PM   #9
Herowe's Avatar
Dealer says, we probably had a flame out of tube issue while driving. We were driving with propane on for fridge. Thermal fuse did it's job.
My guess, we were headed east in the afternoon in Florida. Just got too hot with sun on the rear (our fridge is in the rear). Will now travel with propane off and let fridge just stay cool on it's own.
Dealer says we should bring it in. Since it's under warranty, do not want issues down the road from self repair. I'll drop it with them next Monday.
I did find the fuses on eBay 5 for $1.99 with $1.99 for shipping. But it is slow boat shipping, not like Amazon Prime 2 day. I will be getting a pack of 5 for spares. Looks like this could end up being a common DMR702 problem as frankm was not driving with his.
We'll see how many days this simple repair takes.
Henry & Cindy
2021 Coachmen Encore 325SS
2019 Edge ST
Old 06-11-2017, 06:30 PM   #10
Attachment 134817Attachment 134818
Hi Frank, I have the problem, I dont find the parts , can you help me ?
Patrick1974 is offline   Reply With Quote
Old 06-15-2017, 11:04 AM   #11
Broken Toe
Cowracer's Avatar
I had the same issue. Don't pay the money for the Dometic part. just search amazon for "152 Degree thermal fuse". They are extremely cheap and common.
Write up of my issue/solution here: http://www.forestriverforums.com/for...em-133396.html
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 06-15-2017, 12:00 PM   #12
Ours went out while in Colorado last year - bypassed it to enjoy the week and half left of the trip. Ordered a pack of 10 off Amazon. Replaced it and have not looked back...
Webhair is offline   Reply With Quote
Old 07-05-2017, 01:41 PM   #13
Pillboxmc's Avatar
152 degree, c of f?
All I see is c?
Tbd
2020 Trailhawk toad
Semper Fi
Pillboxmc is offline   Reply With Quote
Old 07-05-2017, 03:15 PM   #14
Broken Toe
Cowracer's Avatar
Originally Posted by Pillboxmc View Post
152 degree, c of f?
All I see is c?
152 Celsius.
Tim
"Camper" 2016
Old 07-05-2017, 08:08 PM   #15
Pillboxmc's Avatar
Thought so but, still does not hurt to ask. Thanks
Tbd
2020 Trailhawk toad
Semper Fi
Old 11-17-2017, 02:26 PM   #16
Hello brand new 2017 Ultra V with the same fridge. first trip out this weekend. Having the same issue went 500 miles with the fridge on gas. Stopped mid trip the fridge was still on. Got to our destination and it’s completely dead no lights. I found the thermo fuse but how do you know if it went bad or not. Is there a way to check it.? Not real happy that I had to go buy a giant cooler and ice to keep all our food for 5 days cold.
Hammerhounds is offline   Reply With Quote
Old 11-17-2017, 04:21 PM   #17
Keystoner's Avatar
There is a thermocoupler screwed to the chimney with a small reset button. Lower down clamped to the back of the fridge is a thermofuse that does not reset. You need a multimeter to check for continuity on both of them. Trace the wire and disconnect one or both ends to run the meter.
Keystoner is offline   Reply With Quote
Old 11-17-2017, 04:24 PM   #18
Broken Toe
Cowracer's Avatar
No lights is probably something else. The blown thermofuse will light up with a trouble code on the display.
Check that you have power going to the unit, both 110vac and the 12vdc.
Tim
"Camper" 2016
Old 11-17-2017, 04:25 PM   #19
Keystoner's Avatar
When my thermofuse blew it cut ALL power to include the interior light.
Here are pictures that I was unable to attach to my initial reply
ID:	156608   Click image for larger version
Old 11-17-2017, 05:16 PM   #20
Old Forester's Avatar
Keystoner is referring to a bi-metallic disc which, when it "pops", will interrupt the circuit and is "resettable", just like the red button on your residential water-heater. It's not a thermocouple. I like these when used for a flue over-temp protector. The thermofuses are one-shot deals used to protect the outside fridge compartment from an over-temp. Just goes to show ya, 60 plus years of learning how to protect us from when our appliances run amok.
Old Forester is offline   Reply With Quote
dometic, fridge, power
