Old 07-10-2016, 06:19 PM   #11
You can use any indoor outdoor thermometer with a sending unit to prevent oppening the fridge to often to check the temp. I keep frozen half gallons of water in the home freezer and put them in the rv fridge and freezer when I first turn it on to help cool it faster. I take them out as I pack the food which should already be cold.
markb422 is offline   Reply With Quote
Old 07-10-2016, 07:19 PM   #12
dmchapman's Avatar
Reagarding thermistor position... Just yesterday I was reading the operating instructions and at the end found two sentences. The thermistor capsule should be centered in the holder (clip). The holder should be centered on the far right-hand fin. Then slide the clip up for colder, down for less cold.
dmchapman is offline   Reply With Quote
Old 07-10-2016, 07:33 PM   #13
Georgetown 280
I know this is somewhat off target, but our driveway is not level, hence when we pack for a trip, we cannot start the fridge. I have found that putting a bowl of ice in both the fridge and freezer work great to get the temperature down when we finally leave and let the cooling take place while on the road. Works fine for us.
Mike and Cheri Ferguson (and Laci)
2013 Georgetown 280
Penn Valley, CA
MikeFerg is offline   Reply With Quote
cooling, dometic
