Old 06-24-2013, 06:30 AM   #1
Door hinges
So the screen door on my rear door (master suite) seems to be binding. Not sure what is going on but when the main door opens, the screen door only opens half way. Ive tried spraying WD40 but to no avail. Anyone else experience this?
2012 Ford F150 Crew Cab 4x4 EcoBoost
2011 Windjammer 3006W
ThePsnaps is offline   Reply With Quote
Old 06-24-2013, 07:54 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
Just a thought
I haven't had that problem, but when I was an auto mechanic, we had a technique for dealing with something with hinges that didn't work properly.
You might try slightly loosening the fasteners that hold the screen door hinges to the trailer. Then open the door and see if something moves. Both hinge pins should be vertical and the edges lined up parallel to the frame.
Hope this works,
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
