Old 02-03-2016, 03:15 PM   #1
Drain valves Rockwood UltraLite 2304 S
Hope I've gotten the right forum for this. We just gotten a used 2007 Rockwood Ultra-lite 2304 S. And I am trying to find the low point drains. I've crawled all over underneath. Found a red hose and a blue hose, underneath, near the frame, just behind the back axle. They are on the street side near the slide out
that holds the couch. No caps on the drain hoses(pipes) no valve handles inside the coach above the area where the outlets are. I've looked under sinks, under the tub, under the couch, behind the fridge. Any ideas?
bilby05 is offline   Reply With Quote
Old 02-03-2016, 03:51 PM   #2
rogo's Avatar
I owned a Rockwood 2604 Ultra Lite (different, I know,) and it had low point drains in about the same location. I had to stick my head underneath to see them. Mine had caps which I removed after blowing out the lines to let any remaining water drain out. I recently traded for a new TT the dealer had already winterized. They had removed the caps. I found them behind the outside shower door.
Roger, Sherrill, and Harley (Great Dane)
2016 Flagstaff V-Lite 30WRLIKS [sold]
2012 F-150 XLT Screw 3.5L EB, 3.55
Air Lift AirCells, Blue Ox BX1500
rogo is offline   Reply With Quote
Old 02-03-2016, 03:56 PM   #3
iluvlcy's Avatar
Our 2011 the low point drains are on passenger side behind wheels near outside wall. Sounds like you found them maybe drain caps are missing? Was it winterized? If that is them you can hook water up and see if the water runs out through them.
Enjoy your trailer we love ours!
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 02-06-2016, 06:50 PM   #4
Found, missing low point drain valves
They were hiding under the bathtub. They did not look like I expected. The panel on the side of the tub comes off with 4 square drive headed screws. To see them you have to lay on the hall/kitchen floor with your head between the toilet and the tub and shine a flashlight under there. I thought they would be "valves" you know with handles of some sort. But they look like large black plastic bolts sticking up perpendicular to the red and blue pex. They seem to work. I'll try to attach a photo.
Thanks to all who provided hints to solve the puzzle. billb
Old 02-07-2016, 11:08 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
That should be your first mod. Leave the existing valves in the "on" position, button 'em up and leave 'em. Then add lever valves to the threaded ends of the pipes under the trailer.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 02-08-2016, 02:28 PM   #6
Thanks.
I hear you there. Trying to crawl under the bathtub to do that is hard on an old man. I am thinking sharkbite fittings. I've used them to completely replumb an older trailer and they're an easy fix. Thanks for your input.
Old 02-08-2016, 02:34 PM   #7
Photos of the original "valves"
See attached.
2304, drain, rockwood, ultralite, valve
