Old 01-05-2016, 03:02 PM   #1
AKA: 'tiredTeacher
awellis3's Avatar
Draining the water heater on 2604
This has happened twice so I thought I'd ask to see if anyone else has noticed this.
We park the TT for January and February. On the way home from our New Year's outing last year and again this year, I noticed the water heater empties completely if we drive home with the low point drains open and all the inside faucets open. I assume it does so by draining out the cold water inlet at the bottom of the tank.
I mention this as a heads up. It makes it a whole lot nicer pulling the anode for inspection knowing the tank is already empty.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-05-2016, 03:16 PM   #2
And all the White Crud Downstream from the W/H Tank! Youroo!!
Old 01-05-2016, 03:30 PM   #3
AKA: 'tiredTeacher
awellis3's Avatar
Actually, it will be upstream on a 2604. On this trailer, there is a straight shot from the WH's cold water inlet to a T. The line continues from the T to the low point drain. The line from the T to the city water connection and the rest of the trailer is the 90 side of the T and runs up. Water drains from the tank to the T, meets all the other water draining from the trailer at the T and continues on its way to the low point drain.
That's why I thought I'd mention this so other 2604 owners would know. It may not work on other models, as you noted.
Wright and Penny
Richmond, Va.
Old 01-05-2016, 03:39 PM   #4
I have never know water to Run Up,but then I dont know where you are! Youroo!!
Old 01-06-2016, 12:23 PM   #5
I like to drain and flush WH first then open low point to avoid the crud.
Harkerr is offline   Reply With Quote
Old 01-06-2016, 10:59 PM   #6
youroo, remember when you used to suck gasoline through a hose to get it to come UP out of the gas tank? Same principal. If you create a siphon, then the water will go UP and then down the hose if the hose end is lower than the water in the hot water tank.
Pat & Karen
Seattle, WA
2012 CC Silverback 29RE
2013 Ford F250 Lariat, Crew Cab, Short Bed, Diesel, 4WD
Retired and trying to travel where it's warm.
pengle is offline   Reply With Quote
2604, drain, heater, water, water heater
