Old 06-02-2012, 08:27 PM   #11
Chuckinca's Avatar
Always off - Refrig stays cold all day and not needed - even in 100 degree weather
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 06-21-2012, 10:35 AM   #12
Always off. Its a flame. Nobody needs that travelling down the road. If the fridge cannot stay cold for 5-6 hours then fridge needs replacing.
Mike101 is offline   Reply With Quote
Old 06-21-2012, 10:56 AM   #13
Mine runs on propane while travelling. The manual even says it's fine. I'm not going to argue with the manufacturer.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 06-21-2012, 11:07 AM   #14
(Kim)
Labzy's Avatar
Agree. If it wasn't meant to be done, manufacturers would have all RV's able to use battery to run the fridge while towing. Mine has two options: propane or electric; since I cannot find an extension cord long enough propane it is!
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 06-21-2012, 12:10 PM   #15
Off, unless trip is more than 4-5 hours. Always off when entering a fuel station.
Len & Cheri is offline   Reply With Quote
Old 06-21-2012, 12:17 PM   #16
daydreaming about camping
jeeplj8's Avatar
I have tried to run with our on 12 volt 2x now, but each time when I set-up the check light is on and the fridge is not cold.
Have pretty much just given up.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 06-21-2012, 12:30 PM   #17
To be real safe I use a cooler with ice in it.I never slide it across the carpet while at a fuel stop,it might cause static electricty and blow up the fuel station. My wife makes sure no one drives up to the other side of the pump island while we are getting fuel,as well as not starting their vehicle until I am finished fueling. Ignition & starters two biggest spark producers. One can never be too safe! Youroo!!
Old 06-21-2012, 12:36 PM   #18
Old 06-21-2012, 12:37 PM   #19
Dallas Texas
TexasBBQ's Avatar
Don't forget to tie down the dog. They tend to create a static charge with their coat.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 06-21-2012, 12:51 PM   #20
Experienced Newbie
This past weekend I ran with the fridge on gas. 1 part to ensure it was working, 1 part to keep/get things cold that I hadn't planned far enough ahead for, 1 part to keep my burgers frozen.
Then ran 90% of Thursday-Saturday on propane due to my generator failing. (Over 20 years old + bumped the fan switch to A/C = POP goes the genny)
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
