Old 05-21-2010, 10:16 PM   #1
scann's Avatar
DSI water heater question
I have a 2011 Rockwood mini-lite 2306 with the dsi water heater and was curious to know if anyone knows how this water heater normally operates? I think there is both a propane burner and an electric element, so if there is an electric element is it normal for the burner to kick in if the trailer is plugged into AC? I thought if the trailer was plugged in it would use the electric element alone to heat the water. I am happy to have really hot water but I am the type of person that likes to know how things work.
scann is offline   Reply With Quote
Old 05-22-2010, 01:03 AM   #2
Cyber Phrenologist
Radio's Avatar
It usually runs on gas unless you force it to run on electric. Or force it to run on both. The switch on the inside of the trailer turns on gas only. There is a small, hard to find switch on the WH itself that will usually have a safety pin to keep it locked out. Turn on that switch and the WH breaker for electric, and turn them both on for gas/electric. I have never used my electric function. Partly out of fear I'll fire it up empty and burn it up and partly because most campground power is low and I'd rather run the air conditioner.
Of course always test to make sure the tank is full before operating the WH anyway.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-22-2010, 06:31 AM   #3
milzat's Avatar
x2, What Radio said........
milzat is offline   Reply With Quote
Old 05-22-2010, 08:16 PM   #4
scann's Avatar
Thanks guys, a picture is worth a thousand words. I would have never seen that button since it is kind of hidden.
Old 05-22-2010, 10:03 PM   #5
Knower of Some Things
YIKES!!!
Rocker switch "on" with water heater empty!!!
DANGER ! DANGER ! DANGER !
PumaPro is offline   Reply With Quote
Old 05-23-2010, 07:39 AM   #6
milzat's Avatar
Originally Posted by PumaPro View Post
YIKES!!!
PumaPro,
Take a good look at the switch again. It may look as if it is in the ON position, but is actually in the OFF position. See the shadow to the lower right of the switch. Photos can fool you.
Old 05-23-2010, 09:42 AM   #7
I leave mine on full time, and control it with the inside circuit breaker that is for the WH. I then have that "to do" item listed on my checklist to switch that off before disconnecting the water or electric, so there's no chance of burning up the element. Randy
Old 05-24-2010, 07:50 AM   #8
Controlling it via the circuit breaker huh?......I like it!! might have to modify my checklist and add that to it, good idea.
2010 Wildwood 31QBSS
2004 Ford F250 6.0 Diesel 4X4
Firestone Airbags
Equalizer Hitch
OSCBRADLEY is offline   Reply With Quote
Old 06-01-2010, 09:44 AM   #9
Thanks to the picture in this thread, I was able to determine that my water heater will run on both electric and gas. I was convinced it ran on gas only. The manual says nothing about running on electricity, and the switch is small and very hard to see. I had to get a flashlight shining back in that area just to see it. I ran on electric all weekend and it worked great. This will save a lot of propane.
grandpaofthree is offline   Reply With Quote
Old 06-01-2010, 10:41 AM   #10
Looking at the switch, it does look like it is in the on position.
The lockout pin on mine goes thru the bottom of the switch.
Kev
kev2504 is offline   Reply With Quote
rockwood
