Old 06-09-2015, 01:36 PM   #11
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Freetyme1....forgot to tell you.....that shroud pulls straight up and off. I could be tight if the bottles are too far apart on the bracket, but it'll slide right off of there.
Grampa Jim is offline   Reply With Quote
Old 06-09-2015, 01:50 PM   #12
Oaklevel's Avatar
Originally Posted by NCBBA11043 View Post
I'm in favor of leaving both tanks valves OPEN (isn't that the reason we have auto-switch regulators?). Doesn't take much to take a look at the visual indicator to see if it's red or green. It would take a long time to drain 30 lbs of propane so you have a lot of time to refill the empty one.
X2
Always keep an eye on them. 30 years of camping never ran both tanks out don't want to get up in the middle of the night to turn the second one on.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-09-2015, 02:52 PM   #13
Retired Techie
Also you may get a false reading if you have no gas being drawn and both lines have pressure like in when you are testing them.
moligney is offline   Reply With Quote
Old 06-09-2015, 03:05 PM   #14
Thanks for all the good info. Think it makes sense now.
Freetyme1 is offline   Reply With Quote
Old 06-09-2015, 06:31 PM   #15
I have actual guages with dials on each of my tanks so I know exactly where each one is at. Got them from a friend who has a local propane business. But I know you can get them at Camping World too.
JoeNanMinn is offline   Reply With Quote
Old 06-09-2015, 07:05 PM   #16
Mddle of the Rd Extremist
MeepMeep's Avatar
Like several others, I've had both bottles empty out with the crossover valve in auto. Probably not much of a problem in the summer, but we're full time and we do use the furnace quite a bit during the winter months when the heat pump/AC can't handle the chill.....for us, the valve stays in manual
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 06-09-2015, 07:30 PM   #17
One tank on at a time, I'd rather get up in the middle of the night and turn the other one on than be cold the rest of the night.
Old 06-10-2015, 08:09 AM   #18
I'm with Meep Meep and Old Coot....one tank at a time.
It's too cold in January at 3 A.M.
Old 06-10-2015, 08:36 AM   #19
1 tank on at a time! Instead of the (Auto Changeover Valve Green/Red Flag) I would much rather have a Alarm go off when (1) tank is used up.I don't care if it is the middle of the Night and 30 deg! Youroo!!
Old 06-10-2015, 08:49 AM   #20
Oakman's Avatar
I would rather get up in the middle of the night and have a bottle to change over to. It’s too easy to forget to check your propane when using the auto changeover feature.
Unfortunately Murphy’s Law states: RV propane bottles only run dry between 2 AM and 3 AM.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
tank
