Originally Posted by Lefty59
Handle on our switch-over valve points towards the tank 'in use'. With both tank valves off you get a red indicator. Turn on the tank 'in use' as indicated by the position of the switch & the indicator goes green if there is propane in the tank. Turn on the opposite side tank & it will auto switch if the primary tank runs empty (nice if you are running the heater in cold weather & don't want to get up in the middle of the night to switch tanks). Indicator will remain red until you manually move the switch to point at the other tank & then the indicator will go back green (unless it's empty as well). You're then good to go to refill the empty tank.
I'd definitely say you have an empty tank.
Safe travels!
I find this very handy. Easy to tell if a tank is low or empty so I know what I need to do:
Propane Level Gauge
I never liked those red and green indicators.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
