10-24-2016, 10:26 AM
Broken Toe
Dual A/C question
My new camper has dual A/C units. One in the living room, one in the bedroom, and I have a couple of questions on how they operate...
I only noticed 1 thermostat in the camper. Do both a/c's run off that one t-stat? Can one A/C be turned off? Do the A/C's share the ducts in the ceiling, or are they separated?
In other words, what do I do if I am stuck at a 30 amp site?
Thanks!
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
10-24-2016, 10:55 AM
All units are plumbed different. Are your controls for the bedroom unit on the unit itself? When you run the main unit, do you get airflow through the bedroom vents? Do you even have bedroom vent outside the unit itself?
If not camping, I am Sailing
10-24-2016, 11:13 AM
Broken Toe
I don't have the camper yet, so I cannot answer some of those questions.
I did not see any controls on the bedroom air, but there definitely was vents in the ceiling.
Even when I get it home, I only have a 30amp plug run to where I will keep it, so I cant really run both airs at the same time till I upgrade that outlet.
Tim
10-24-2016, 11:15 AM
My guess then is, main unit vents into bedroom. Bedroom unit has controls only on ceiling and works only in bedroom.
10-25-2016, 11:21 AM
When you looked at the thermostat, was it square or rectangular? If it was square then it won't control both units. There are thermostats that control multiple zones, but normally on your RV the main A/C is controlled by the thermostat and the aux (bedroom) unit has manual controls on the air box.
Gotta go campin!
10-25-2016, 11:55 AM
I would guess this too. Unless a higher end rig with a more elaborate hvac system, chances are...
The main living room unit is controlled by the thermostat and vents into all rooms, including the bedroom.
-and-
The second unit, located in the bedroom, is not ducted and just dumps out the ceiling cover... and the manual controls are directly on the unit.
But there are many different implementations, so I could be wrong. [emoji846]
10-25-2016, 12:06 PM
Our Silverback has Dometic A/C's. One in bedroom and one in living area. We have one controller that controls each unit individually. This is a link to the manual... http://dometic3frontend.qbank.se/epi...968c73ab73.pdf
If you are at a 30 amp site you select the zone button until the zone you want to turn on or off is selected. You then toggle with the mode button to turn on/off, select cool or furnace (no furnace for BR a/c), etc.
Hope this helps...
10-25-2016, 12:08 PM
You did not mention what model you are buying or I missed it but in our unit the vent system is a race that loops from the back to the bedroom. When any ac is on air comes from all vents...
10-25-2016, 12:13 PM
Failure is my business
My Flagstaff 832IKBS (Identical layout to your 8329SS, I believe) has the second controller for the bedroom AC mounted on the rear facing side of the clothes closet in the bedroom. (Near where the second TV would mount.) It has two Coleman Mach units for what it's worth.
The bedroom unit has a small heat pump built into it as well.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
10-25-2016, 02:17 PM
I ordered the Rockwood 2905WS, with the dual A/Cs. i don't have it yet either, but it states with dual A/C units on the newer ones, they have a dual control on the wall. That should be what you are getting as well I am assuming, but again, that's based off what i am getting which is a 2017.5
2017.5 Rockwood Ultra Lite 2905WS (all the options)
New TV- 2017 Ram 3500 SRW Sport 4X4
Old TV- 2007 Dodge Ram 1500 Sport (Hemi)- towing vehicle
10-25-2016, 02:34 PM
Broken Toe
You are correct sir!
While I don't have my grubby little hands on my new camper yet, the dealer still has pictures of it on their website. I got to looking at them and I see the bedroom t-stat right were you said it would be, on the rear side of the closet.
BTW, in case any of you are interested, here is the link to the pictures of my new camper
New 2016 Forest River RV Rockwood Signature Ultra Lite 8329SS Travel Trailer at BT Camper | Wentzville, MO | #7708
Tim
10-29-2016, 07:06 AM
Not to change the subject but be careful opening the wardrobe doors. The locks are cheap plastic and i broke mine on week 2. Love the trailer but they could have done a better job with the door locks on wardrobe.
Ken
2017 Rockwood 8329SS
2012 Ford F250 King Ranch
6.7 TD Super Crew
"Go Navy"
10-30-2016, 08:18 AM
We usually only run one A/C once we get the RV cooled down. If you turn A/C on before the heat of the day ramps up you run just one and keep it cool inside. We found that when watching tv or having a quiet conversation we will run bedroom A/C to help with noise.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
10-30-2016, 08:33 AM
Thats a great idea. As both ACs in the 8329ss are ducted together that would cut down on noise.
Ken
6.7 TD Super Crew
"Go Navy"
