Old 08-12-2013, 07:55 AM   #1
Dual byapss valves
My 2009 Rockwood 2306 has two bypass valves. One in to the hot water heater and one on the out line that that controls and mixes with a cold line.
Is this additional valve on the out line a "feature" to control the temperature of the water? If it is all the way open-it is impossible to get anything more than lukewarm water.
bob4apples is offline   Reply With Quote
Old 08-12-2013, 12:26 PM   #2
Dave_Monica's Avatar
Does the piping on the back of the water heater look like this?
Dave
Old 08-12-2013, 07:32 PM   #3
yes--very close to that
Old 08-12-2013, 08:25 PM   #4
Paul & Sheri
pwb01's Avatar
In my Sunline I had two valves that looked like the photo. Each valve directed the water either straight through to the the heater (no by pass) or to the bypass pipe isolating the heater for winterizing. Not intended to mix water.
Make sure they are both fully open to straight through position so no water is directed to the by pass pipe for hot water. The lever is the direction of flow so horizontal is to the heater, vertical is bypass
I have three on/off valves now in the Rockwood. After winterizing for the first time last winter, I opened the valves for flushing this season. My first trip was in 40 degree weather and my water heater wasn't working. Cold showers! On the last day I checked and found I left the third valve open on the by pass pipe allowing the water to by pass the heater.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
valve
