Old 06-06-2015, 04:03 AM   #1
ColoradoRick's Avatar
Electric & Gas Water Heater Recovery Time
When we traded in our old 18-footer for Rocky, our PDI introduced us to the dual water heater. (Heats the water with both electricity and with propane.)
I asked him if I used both would it work (recover) faster and he said, "Absolutely not, that's a common myth among RVers."
I've never, actually, tested this but was wondering what the consensus is amongst y'all?
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 06-06-2015, 04:33 AM   #2
fonzie's Avatar
Using both at same time will recover much faster. Did not actually timed it but when I had 6 people using shower one after another, I did not ran out of hot water as when only on electric after 3 showers water started to get cold.......
https://www.google.ca/search?q=recov...BoeoyASij4KgCg
Fonzie
Old 06-06-2015, 05:28 AM   #3
Herk7769's Avatar
Personal experience: recovers faster with two heat sources.
Should make sense since there are two different heat sources working to raise the temperature at the same time. It will NOT make the water "hotter" since the independent thermostats determine when they shut off and they are set to the same temperature.
HAM CALLSIGN - KC3FFW
Old 06-06-2015, 06:42 AM   #4
camping baba's Avatar
Hot water
With both gas and electric my wife can now enjoy her shower . Remember not to turn on the electric until there is water in the water heater .😃
camping baba is offline   Reply With Quote
Old 06-06-2015, 07:11 AM   #5
wmtire's Avatar
If you see this PDI person again, you need to see if he will contact the manufacturers, so the builders of these water heaters will quit perpetuating this "myth". What would they know, huh?
Suburban's website (emboldened below):
Airxcel | Suburban Manufacturing Products
  • Faster Recovery
    Fast recovery means more hot water and fewer cool water cycles. Six-, 10-, 12- and 16-gallon Suburban gas water heaters feature 12,000 BTUH input and a recovery rate of 10.2 gallons per hour - that's the fastest in the industry. Combination gas/electric models also use a 1,440-watt element to recover an additional 6.0 gallons per hour at campsites. For higher recovery, both the gas and electric element may be used simultaneously.
  • Suburban also uses a copolymer insulation jacket specially molded to fit the tank. This does a better job of retaining heat than the "cardboard" style used on some competitive models.
  • Examine some of the many options available with Suburban Water Heaters.
  • View the specifications for all of our Water Heater models.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-06-2015, 07:24 AM   #6
wmtire's Avatar
To add to my above post, Atwood even has a recovery chart in their water heater brochures that shows the amount of water heater recovery on electric, or gas, or the combination.
http://www.atwoodmobile.com/images/waterheater.pdf
I would have to doubt the PDI's person training if he made a comment like that. Here is a FAQ on the operation of Suburban water heater, just so you can check to see if he was trained correct on it too.
Suburban's electric switch and much more
Old 06-06-2015, 08:04 AM   #7
53flattie's Avatar
How would one turn on both heating sources? (RW MiniLite 2306)
2015 Rockwood 2306
2006 Toyota Tacoma
53flattie is offline   Reply With Quote
Old 06-06-2015, 08:18 AM   #8
wmtire's Avatar
2015 Rockwood 2306
2006 Toyota Tacoma
If you have the Suburban, it in the last link in the post right above yours.
'Suburbans electric switch and much more'
Old 06-06-2015, 12:37 PM   #9
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Colorado Rick...Fonzie is right on. I've been doing it for years. It is faster with both on....BUT...do keep in mind like Camping Baba said.....never turn on the electric until the heater is full. AND,,,keep in mind,,,,,if you fill it without opening a hot water line in the RV to bleed out air,,,,it'll ruin your day when your element smokes. Look into a sacrificial anode too. They're great to preserve the walls of a heater. I use them on ALL my heaters regardless of whether they need them or not. They ALL need them,,,,,the ions in the water eating up the anode instead of the heater is the proof in the pudding.
Grampa Jim is offline   Reply With Quote
Old 06-06-2015, 01:00 PM   #10
Best way to bleed the air out of the water heater is by the pressure relief valve located at the top of the wh compartment.
cover, electric, gas, heater, water, water heater
