Old 04-10-2011, 08:06 PM   #1
Electric Hot water heater help!!
I have a 2011 Windjammer 3002W. I just bought it. I turned on the hot water heater rocker switch above the TV and the gas fires up the water heater. I want to use electric, why wont this work. I have looked for a switch and cannot find one around the water heater. I have turned the circuit breaker on and off. Help....
dsherold is offline   Reply With Quote
Old 04-10-2011, 08:15 PM   #2
kalik282's Avatar
See this thread...
Water Heater
Has the info you seek complete with pic.
John
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 04-10-2011, 08:15 PM   #3
sherdep's Avatar
if you turn the switch for gas off and go back out to the water heater on the bottom left hand corner behind the pipe you will see a rocker switch - it may have a pin in it - pull pin and push to on - when you are packing up make sure to turn the switch off
the tank should have water in it before flipping to on - hope that helps if it doesnt I know I can find a picture around here somewhere for you
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-10-2011, 08:16 PM   #4
sherdep's Avatar
Originally Posted by kalik282 View Post
See this thread...
Water Heater
John
Well Done John - you beat me to it
Old 04-10-2011, 08:44 PM   #5
wow..thank you. This is so great (the pic)...now I have figured it out. You would think they would have better instructions and a better place to put this switch...thanks everyone!!!
Old 04-10-2011, 08:49 PM   #6
If you have only 30 amp service, and try to run the water heater on electric, the AC, the fridge, the microwave, and anything else, you will start tripping breakers, usually the 30 amp. It is not always best to use the electric portion of the water heater. That is why the switch is hard to find.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-10-2011, 08:54 PM   #7
kalik282's Avatar
Glad you figured it out.
Here's a great link to a mod (Posted by Willis) to add a switch INSIDE the camper...
Water Heater Switch with Power-on Light
John
John & Nicole
Old 07-10-2011, 01:46 PM   #8
I was wondering why I kept hearing the burner on the water heater this weekend. I assumed being plugged in it would switch to the electric like the fridge. Add this to another thing that the walk trough did not explain to us..
Hybrid21SS is offline   Reply With Quote
