Old 07-01-2015, 03:00 PM   #11
Charliec's Avatar
The crank attaches on the opposite end from the motor. Don't have my TT here and only did it once so I don't remember the detail but there is a place there to attach the crank.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 07-02-2015, 03:14 AM   #12
Just a member
kandl's Avatar
Originally Posted by redcloud1 View Post
Yes it does
You might want to look at that again. The crank for the tongue jack is unique. It's a socket welded to the end of the crank. The crank for the stabilizers is typically dual purpose - manually actuate the stabilizers (with power disconnected) or manually crank the slide motor.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-02-2015, 04:39 AM   #13
Don't do it this way! Motor and Gearbox were broken off by a (Alligator)! Simply go to other side of unit and use the (Supplied?) Socket Crank! Youroo!!
Old 07-03-2015, 02:06 AM   #14
Just a member
kandl's Avatar
That's pretty crazy! You caught him in the act?
Old 07-03-2015, 03:09 AM   #15
wmtire's Avatar
Down here in Louisiana, we have plenty of both kinds of gators. I am taking it, that yours was of the rubber variety and black.
http://blog.allstate.com/dont-let-road-gators-bite/
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-03-2015, 03:43 AM   #16
Just a member
kandl's Avatar
Hey! I learned something today. Too cute. Interesting little tidbit re NHTSA data on tire failures. Who knew?
Old 07-18-2015, 11:26 AM   #17
Put it somewhere in the back of your mind, to remember to heed the warning in the Lippert brochure about disconnecting power before using the manual crank:
WARNING!
Always disconnect battery from system prior to manually operating system. Failure to disconnect battery can cause electricity to backfeed through the motor and cause serious damage to the system as well as void the warranty.
Help me understand this. If the switch is not being pressed while the jacks are being manually turned, is there really a need to disconnect the power? Isn't the switch effectively disconnecting the power anyway?
My rear jacks won't go down and I don't have the proper socket to manually extend them either. Heading out to get a VOM to troubleshoot.
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
tmhudg is offline   Reply With Quote
Old 07-18-2015, 11:50 AM   #18
Those jacks are still being used after a few minor adjustments. Thanks Herk and Gary.
Old 07-18-2015, 01:38 PM   #19
Just a member
kandl's Avatar
Provided the switch is functional, it should effectively cut power to the jack. The caution assumes that you're cranking the jacks by hand because something is wrong with the motor/s or electrical. In that case, and without knowing what's wrong, you'd want to remove power. Too easy to pull the fuse at the converter - should be 20-amp.
Old 07-18-2015, 02:04 PM   #20
Good point. No idea which fuse it is though.
Off to probe...
electric, jacks
