Old 07-18-2015, 02:28 PM   #21
Just a member
kandl's Avatar
Originally Posted by tmhudg View Post
Good point. No idea which fuse it is though.
Off to probe...
Fuse panel not labelled? That can be a PITA.
FWIW... our fuse is out permanently because I can manually crank the stabs down/up exponentially faster than the motors do. They are laboriously slow.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-18-2015, 02:49 PM   #22
redcloud1's Avatar
I have one question, our Windjammer has a battery disconnect, if you pulled the battery disconnect would that in effect cut power to those motors?
redcloud1 is offline   Reply With Quote
Old 07-18-2015, 02:59 PM   #23
Just a member
kandl's Avatar
Yep, it should. Easy to confirm that - activate the battery disconnect and press one of the the stab switches.
Old 07-18-2015, 03:04 PM   #24
Georgia Frog Rally 2018
aceinspp's Avatar
Yes it will. I thought my battery had died when the camper was at the dealer for 3 weeks went to hook up, jack would not work checked the cut off, sure enough they had turn to off. Switch to on and away it goes. Later RJd
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 03:43 PM   #25
Fixed it. Turned out that the connection to the resettable breaker was loose. Both posts were quite rusty too. I couldn't even get a beep when I touched them with my meter. Cleaned them up and tightened down good and bingo - jacks are working again.
Any idea where to get the socket with the slots for manual cranking?
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
tmhudg is offline   Reply With Quote
Old 07-18-2015, 04:05 PM   #26
aceinspp's Avatar
Thanks for the solution to the problem. Might try a camper place. Should have got one with the camper if it was purchased new. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 04:25 PM   #27
Iwannacamp's Avatar
Hmmm. In the old days...a d/c motor was turned without village...it acted as a generator. This would then cause voltage to back feed to the control board....maybe this why.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 07-18-2015, 07:56 PM   #28
No need to be snarky. I understand that a DC motor can be a generator. My question was around why I needed to disconnect if the switch was already disconnecting due to not being pressed. Kandl correctly pointed out that the switch could be malfunctioning and "on" thus disconnecting provides an extra measure of safety. That's the part I hadn't considered. Not that there can be a back feed.
Old 07-18-2015, 10:32 PM   #29
Didn't sound snarky to me. Sounded like someone trying to help.
2011 Traverse LT, 3.6L, FWD
Old 07-19-2015, 12:37 PM   #30
Iwannacamp's Avatar
Amen...
Another helpful idea..maybe you are reversing polarity and it charging the ground..low amps can pop electronics.
2017 Puma 297RLSS
electric, jacks
