07-18-2015, 02:28 PM
#21
Just a member
Originally Posted by tmhudg
Good point. No idea which fuse it is though.
Off to probe...
Fuse panel not labelled? That can be a PITA.
FWIW... our fuse is out permanently because I can manually crank the stabs down/up exponentially faster than the motors do. They are laboriously slow.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
07-18-2015, 02:49 PM
#22
I have one question, our Windjammer has a battery disconnect, if you pulled the battery disconnect would that in effect cut power to those motors?
07-18-2015, 02:59 PM
#23
Just a member
Yep, it should. Easy to confirm that - activate the battery disconnect and press one of the the stab switches.
07-18-2015, 03:04 PM
#24
Georgia Rally Coordinator
Yes it will. I thought my battery had died when the camper was at the dealer for 3 weeks went to hook up, jack would not work checked the cut off, sure enough they had turn to off. Switch to on and away it goes. Later RJd
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-18-2015, 03:43 PM
#25
Fixed it. Turned out that the connection to the resettable breaker was loose. Both posts were quite rusty too. I couldn't even get a beep when I touched them with my meter. Cleaned them up and tightened down good and bingo - jacks are working again.
Any idea where to get the socket with the slots for manual cranking?
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
07-18-2015, 04:05 PM
#26
Thanks for the solution to the problem. Might try a camper place. Should have got one with the camper if it was purchased new. Later RJD
Days camped 2019 62
07-18-2015, 04:25 PM
#27
Hmmm. In the old days...a d/c motor was turned without village...it acted as a generator. This would then cause voltage to back feed to the control board....maybe this why.
2017 Puma 297RLSS
07-18-2015, 07:56 PM
#28
No need to be snarky. I understand that a DC motor can be a generator. My question was around why I needed to disconnect if the switch was already disconnecting due to not being pressed. Kandl correctly pointed out that the switch could be malfunctioning and "on" thus disconnecting provides an extra measure of safety. That's the part I hadn't considered. Not that there can be a back feed.
07-18-2015, 10:32 PM
#29
Didn't sound snarky to me. Sounded like someone trying to help.
2011 Traverse LT, 3.6L, FWD
07-19-2015, 12:37 PM
#30
Amen...
Another helpful idea..maybe you are reversing polarity and it charging the ground..low amps can pop electronics.
2017 Puma 297RLSS
07-19-2015, 05:46 PM
#31
Originally Posted by Iwannacamp
Amen...
Okay, I guess "Back in the old days,... a motor can be a generator..." Sounded condescending to me. Apologies if I misread.
Nevertheless, as I've tried to explain, I wasn't disputing that back voltage could damage something. It was how could the voltage be applied if the switch was open.
At least one person got it so I don't think it was totally unclear.
