Old 07-12-2011, 08:21 PM   #1
Question Electric outlets have no power
I have a 2011 minilite 2502s. I had battery problems and changed to new ones and used a generator 2500 and now I've no power in electrical outlets though I'm checked fuses
Williamhay is offline   Reply With Quote
Old 07-12-2011, 08:27 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Did you check the output on the generator first? Then check the electrical panel to see if any breakers are tripped or just turned off. Also check your receptacles. One or two of them will be a GFIC type receptacle. Press the test button , then the reset button and see if you have power. Welcome to the Forums.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-12-2011, 08:27 PM   #3
Coops1's Avatar
All of the 120V outlets should have Breakers, try turning them off then back on. The other thing to look at would be your GFCI plugs to see if they need resetting.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 07-12-2011, 08:49 PM   #4
Thank you, I'd pressed the GFCI plug and the light went on but since I'd done the other suggestions I pressed that one more. The light went out, I'd thought the light was a good thing. Now that light is off and all the outlets work. Wow! Thanks.
