Old 05-24-2013, 12:48 PM   #21
I'd like to know for those who used grease was there an audible noisy problem prior to applying the grease? And if so did it fix it?
I tried dry lubricant and also tried candle wax and neither one resolved my noisy jacks problem...
hayesb2 is offline   Reply With Quote
Old 05-24-2013, 01:00 PM   #22
mgargiullo's Avatar
I found that the majority of the noise on mine wasn't coming from the threaded parts, but from the 'thrust bearing'. Which was nothing more than a couple of large fender washers on my setup. It cut a huge amount of noise lubing those.
2017 GMC 3500 Denali HD
2010 Rockwood Signature 8316SS
mgargiullo is offline   Reply With Quote
Old 05-24-2013, 02:03 PM   #23
My legs took a few tries to get moving and when did were groaning the whole way down. The far one woul not extend until the closest was down and pressure on it. After I Lithiumed the whole thing, they make no noise and come down at the same time. Where the leg goes into the channel when retracted is metal on metal so spray really helped. Short answer; noise before, no noise after
Mike - Ottawa
'10 Rockwood 8280ws
2014 Ram 2500 SLT HD Crew Cab 4X4 3.73
Mike101 is offline   Reply With Quote
