Old 10-08-2013, 03:41 PM   #1
Electric trailer jack
Hi I am going to install a electric trailer jack I purchased from Harbor tools It is a 3,500 # item #67597. this is going on a 2003 rockwood TT model #82725-27'. Has anbody done this or are their any suggestions. It seem to be fairly straight forward to install. I will hook the electric directry to the battery with out a seppart switch and can un hook the connection if need be.
ray Kalinsky 2005 ford 150 conversion van.
RAYSR is offline   Reply With Quote
Old 10-08-2013, 04:07 PM   #2
jtstromsburg's Avatar
Yup. Pretty straightforward. I would definitely install an inline fuse if there isn't one included.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-08-2013, 04:15 PM   #3
thanks for the reply. What size fuse would be best?
Old 10-08-2013, 05:28 PM   #4
I don't see an amps rating, but would guess 15-20? If you can find the rating on the Jack, which there should be, if go by that and maybe one size bigger. So if the Jack says 7 amp, go with a 10. Lois like good reviews. One wire hookup should be plenty rest if it bolts right up.
Good luck!
Joel and Teresa
2016 Sabre 34TBOK
Old 10-09-2013, 08:13 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Use a 30A. Under load that jack can draw 24A. I put in a 30A, auto-reset circuit breaker.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 10-09-2013, 11:14 AM   #6
raspivey's Avatar
Really easy mod and worth every penny. If my new one hadn't come with one, I'd have immediately put one on. I bent the manual jack on my popup being stupid and replaced it with electric. I think it took a total of 30 min. Hooked up, three bolts off, three bolts on, ring connector to the battery, unhitch. I'm pretty sure it'll come with an inline fuse...I don't remember what size mine had.
Old 10-09-2013, 11:38 AM   #7
I would be shocked if it did not come with an inline fuse ....
Enjoy it It will make your life very easy !
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 10-09-2013, 01:16 PM   #8
Thanks to all for the great replys. some info this jack sells for $139.00 and harbor offers a 25% off coupon on their web. also if you spend $120.00 you can get an electric light temp reding tool. I'm always happy when I get a bargin and others think the product is great.
Thanks again we are heading for the covered bridge fes in In, this week end
electric, trailer
