Old 10-01-2016, 11:58 PM   #11
Originally Posted by Michael Tangora View Post
Mike the
My electric hot water switch is on and the interior wall switch for the water switch is on and the water is full in the heater. Still no hot water from the electriv. Gas is fine
It may not be plugged in.
fella10 is offline   Reply With Quote
Old 10-02-2016, 12:34 AM   #12
Electric water heater
My rocker switch went bad this summer, tested it with a volt meter. Found out it was faulty and went to a local hardware store and replaced it for a few bucks.
litz is offline   Reply With Quote
Old 10-02-2016, 09:42 AM   #13
Wolverine 1945's Avatar
Aren't there reset bottoms under the rubber on the back of the heater ???
Can the element be check with a volt meter,,, by checking for continuity ???
Wolverine 1945 is offline   Reply With Quote
Old 10-02-2016, 09:45 AM   #14
Originally Posted by jftrombley View Post
Have you tried resetting the safety switches. They are located top left under the rubber rectangle. One is for AC and the other for 12VDC. Just depress till you hear a click or keep it pressed for a few seconds. I discovered this on our last trip and finally got the heater to work.
Sorry I missed this one !!!
Old 10-02-2016, 10:25 AM   #15
VinceU's Avatar
Good chance the thermostat or overload on AC side supply are open, they are in series Located under rubber flex cover. Use a meter to check continuity between points, happened to me
Old 10-02-2016, 07:06 PM   #16
I really don't use the electric wh because I have a 30 amp. Electric wh takes a lot of power. I usually turn the gas wh 10 minutes before take a shower and that's enough.
Hman0109 is offline   Reply With Quote
Old 10-02-2016, 08:35 PM   #17
KathyEd's Avatar
Question. Have you ever gotten hot water? Reason I ask is the water bypass could be wrong by the heater. I had the valves turned wrong at the beginning of the season. Once I got the right I got hot water.
KathyEd is offline   Reply With Quote
Old 10-03-2016, 08:54 AM   #18
30 amp systems is what most of us have,,, plenty of amps to run a WH ???
Old 10-03-2016, 09:04 AM   #19
The OP said it works fine on propane.
I'm wondering if somewhere along the way it was turned on without water (on electric) and fried the element?
Mike... you are going to have to do some electrical testing with a meter.
If you are uncomfortable with that, you'll need to take it in for repairs or call a mobile tech.
If you have a meter and know how to use it, let us know and we can walk you through some basic tests.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 10-03-2016, 09:12 AM   #20
Or just remove the ele element,,, and inspect it ???
electric, heater, water, water heater
