Old 09-29-2016, 04:44 PM   #1
Electric water heater
How does it work? My Mini lite #2109S has option for gas or electric. The electric switch is turned on but no hot water.
Any suggestions?
Michael Tangora is offline   Reply With Quote
Old 09-29-2016, 05:08 PM   #2
There is a switch on the water heater itself and a circuit breaker in the breaker panel dedicated to the electric water heater. They both have to be on in addition to the wall switch that controls the water heater.
Hope this helps,
John U
BTW I always run both gas and electric, keeps the water hotter and has quicker recovery than either system by itself.
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 09-29-2016, 05:18 PM   #3
If in your post you are referring to the breaker switch in the power panel inside, ... then there is also a switch in the outside panel, ... lower left, sort of hidden behind tubing,..... its a small rocker switch which has to be "on" also,.....
ID:	121647   Click image for larger version
ID:	121648   Click image for larger version
fella10 is online now   Reply With Quote
Old 09-29-2016, 05:42 PM   #4
wmtire's Avatar
if you have a Suburban brand, this may help, as there is often confusion on what switch controls what:
Suburban's electric switch and much more
Another thing to check for is the winter bypass valves being set for winter and not for normal use. It's also explained in the link above.
2011 Flagstaff 831 RLBSS
At the end of the day, it's dark.
Old 09-29-2016, 05:43 PM   #5
Bluepill's Avatar
Reminder that wh must be full of water first.
2008 Itasca Meridian 37H
Old 09-29-2016, 07:51 PM   #6
raspivey's Avatar
Yep, and if it wasn't, that's probably why it's not hot (toasted element).
But, yes, go through WMTIRE's link and make sure all is right.
2012 Chevy Tahoe LTZ - HD tow package
Old 09-30-2016, 03:06 PM   #7
jftrombley's Avatar
Have you tried resetting the safety switches. They are located top left under the rubber rectangle. One is for AC and the other for 12VDC. Just depress till you hear a click or keep it pressed for a few seconds. I discovered this on our last trip and finally got the heater to work.
jftrombley is offline   Reply With Quote
Old 09-30-2016, 06:49 PM   #8
rockfossilman's Avatar
Suburban also has the habit of hiding the rocker switch behind a piece of foil - we were on our 4th trip before I found ours!
Rockfossilman - Western PA
Rockwood UL 2604ws - Expedition 5.4L
Year-Days/Miles/Trips/Campgrounds
2013 to 2014-27/2444/7/7
2015-36/3245/8/9
2016-61/3277/9/10
rockfossilman is offline   Reply With Quote
Old 10-01-2016, 10:45 AM   #9
Wolverine 1945's Avatar
I guess Michael is no longer talking ???
Wolverine 1945 is offline   Reply With Quote
Old 10-01-2016, 10:46 PM   #10
Mike the
My electric hot water switch is on and the interior wall switch for the water switch is on and the water is full in the heater. Still no hot water from the electriv. Gas is fine
electric, heater, water, water heater
