Old 06-05-2014, 09:39 PM   #1
Electrical outlets
We have a 2013 8289WS. We sold our 40' Tiffin Phaeton and bought a 8289WS. It was a adjustment but we like being able to tow it with a F150. I just wish FR would add more electrical outlets in the kitchen and dining area. I also don't care for the size of the bathroom. Way too small and the door opens up and hangs over the stairs from kitchen to bedroom. Poor design there. Anyone else have these complaints as well? Any suggestions or ideas to correct these flaws? Other than that....pretty happy
Sent from my GT-P7510 using Forest River Forums mobile app
Dkjones28 is offline   Reply With Quote
Old 06-07-2014, 09:50 AM   #2
PhoneDude 8289's Avatar
I added a 110V 20A outlet 12ga wire to the kitchen area just for our toaster oven. It is on it's own 20A breaker, now we can make coffee and use the toaster oven at the same time. Bathroom is tight, our bathroom door opens to the inside of the bathroom, FR must have made that change in the 2014 models.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-07-2014, 10:49 AM   #3
Sounds like a good idea. Ours is a 2013 5th wheel. Not sure if we are talking about the same. Thanks for the info. That is the problem we have. A toaster oven is the problem for us. I refuse to use the stove top or the oven. Just afraid of it and would rather cook with electric. I tried to find a replacement for the microwave that had convection feature but thought the Black & Decker 6 slice toaster oven would be OK. It will cook biscuits in a jiffy and is plenty big enough
Sent from my SM-N900V using Forest River Forums mobile app
Old 07-20-2014, 02:48 PM   #4
Presley one....can you run coffee maker, toaster oven and A/C at the same time?
Sent from my SPH-L600 using Forest River Forums mobile app
Old 07-20-2014, 10:04 PM   #5
About the only problem I have with the 2604 ws is no outlets in the kitchen ? Not sure what they were thinking when they wired it up.
2014 Rockwood 2604 WS
Chev 4x4 2500 HD v8
tugger is offline   Reply With Quote
Old 07-20-2014, 10:49 PM   #6
Can't run all 3 at once. Going to run another electric outlet on a separate feed
Old 07-25-2014, 05:32 AM   #7
dtomstant's Avatar
Problem as I see it is balancing out the A and B side of the 50 amp breaker, especially when you happen to be on a 30 amp source. Surge guard has helped but I'll probably still have to do some rewriting or add an additional outlet to balance the way we load the electrical.
2014 8289WS
dtomstant is offline   Reply With Quote
Old 07-25-2014, 07:16 AM   #8
Coffee maker and toaster oven is a yes, along with the A/C not sure. I'll be checking that out this coming week. We have the 50amp service with two A/C units. We are having 100* + temps so it should be a good test.
Joe & Beverly
2014 8289WS lifted
Old 07-25-2014, 07:58 AM   #9
AKA: 'tiredTeacher
awellis3's Avatar
How many things are you plugging in? We have that trailer and find the single outlet is plenty since we just run a coffee maker and a lamp for nighttime ambience.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-25-2014, 10:45 AM   #10
dtomstant's Avatar
With 50 amp source, we would normally run the front air (14 amps on the B side), allowing us to run coffee maker (15 amps periodic draw) and microwave or toaster oven (15 amps each) on the A side. Forward air flows down hill into main area of RV keeping it cool and relatively quiet. With 30 amp source you can run air on one side, and one heavy draw appliance (15 amp) on the other. In either case the surge guard will show you exactly what's happening on both circuits.
Old 07-25-2014, 01:27 PM   #11
Same problem with our 30RKSS. We have nice kitchen with a 4 foot island. It would have been nice to have had an outlet on the island to plug something into. Currently it's a surge protector from under the living room window Velcro-ed to the underside of the counter top. It works well enough but the cord is ugly.
David 01 is offline   Reply With Quote
Old 07-26-2014, 07:41 AM   #12
I thought the same thing but finally found one on the under side of cabinet by the stove hood. Had the trailer a couple of months before i found it I was going to install one then chasing out wire found it . I do have the 2608ws if that really makes a difference.
Rockwood 2608WS
Paul
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 07-27-2014, 12:50 PM   #13
Thank you Big Paul! I checked our 8289WS and sure enough there is one. I am a happy camper now!
Old 07-27-2014, 01:36 PM   #14
Its not a matter of how many things to plug in the only outlet in the kitchen is on the counter by the entrance door which leaves the cord hanging down as you come in and with grand kids it would be very easy to catch the cord and upset what ever is plugged in, the only other ones are at the very back of the trailer with one by each chair.
I was hoping I could find another one somewhere but failed might also have been nice to at least have one by the table..
Chev 4x4 2500 HD v8
Old 08-03-2014, 10:59 AM   #15
Hawksclaw554
On my 2014 8289ws I wish they had put and outlet behind the sofa for the air mattress that came with it. Have to run cord to center island to plug in.
Hawksclaw is offline   Reply With Quote
Old 08-03-2014, 01:34 PM   #16
dtomstant's Avatar
The dedicated outlet for the air mattress is the one in the back left corner beside the left Lazyboy, isn't it?
Old 08-03-2014, 04:58 PM   #17
I use that one but also have one built into the end table by the recliner
electric, electrical
