Old 03-26-2013, 11:58 PM   #11
We have a 2702ss which had a similar problem. I believe both jacks are wired together on a 20 amp fuse. Our box is under the fridge. Replace and you should be good. Ours was a result of a bent screw on the rear causing a little added stress as well.
2012 Rockwood Ultralight 2702ss
Toyota Tundra 5.7 4x4 Texas Edition
22stoy is offline   Reply With Quote
Old 03-27-2013, 06:24 AM   #12
TURBS's Avatar
I'm working a solution to this issue stay tuned.
Turbs
Old 03-27-2013, 06:47 AM   #13
Also dont try to (Double Team) the jacks at the same time(you & wife or you & kid or? The fuse/S/B will blow also. Most TT are wired together front & back for the S/jacks. Youroo!!
youroo is online now   Reply With Quote
Old 03-28-2013, 08:47 PM   #14
I kept blowing our 15amp fuse on our 2604 and I found that if I stop the jack an inch or so short of retracting against the framerail and then bump the switch only until the jack bolt touches the frame, the blown fuse issue disappeared.
bill.morrison is offline   Reply With Quote
Old 05-29-2013, 08:50 PM   #15
I have a 2013 wildwood xlite 261bh with electric jacks and tongue jacks. I also have a remote that runs the jacks and awning. The remote no longer runs just the rear jacks, but runs the awnings and front jacks fine. I can hear a relay clicking the same as when i run the front jacks with the remote. The rear jacks work fine with the button on the trailer, just not the remote. Any ideas before i tow it into the dealer 70 miles away? We had the tongue jack up and put some stress on the rear jacks the last time we packed up, but the remote worked fine then...
richh is offline   Reply With Quote
Old 05-29-2013, 09:39 PM   #16
Last time I lowered my jacks on my Rockwood 8329SS that I recently purchased the stabilizers only worked when I was plugged into shore power. I just assumed thats how they worked but apparently more investigation is in order....Anybody else experience this?
BMWPilot is offline   Reply With Quote
Old 05-29-2013, 11:53 PM   #17
Hutch333id's Avatar
My 8315bss did the same at the weekend. When I switch the battery isolation switch back into the on position ( green light under the fridge) the stabilizers worked on battery power.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 05-30-2013, 06:11 AM   #18
I was thinking about that after I posted. The battery switch was in the disconnect position. I will check it again this weekend. That was one thing the dealer never explained during the orientation. Tks!
Old 05-30-2013, 01:36 PM   #19
AKA: 'tiredTeacher
awellis3's Avatar
I was thinking about that after I posted. The battery switch was in the disconnect position!
That is it. The stabs are the only outside electrical that runs through the fuse panel. The tongue jack, tongue light and e-brake run directly from the battery.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-15-2017, 07:30 AM   #20
Smile Stabilizer Jacks Remote Not Working
I had the clicking sound coming from somewhere when I pressed the button on my stabilizer jacks remote. The remote would not operate the jacks, but would operate the awning. I started tracing the clicking sound, and discovered an auxiliary fuse panel on the floor under the sink in my Salem Cruise Lite 171RBXL. In the panel were fuses for the jacks, awning and other items, clearly labeled. I pulled the jacks fuse and found that it was blown. Replacing the fuse solved the problem.
gabednar is offline   Reply With Quote
