Old 03-26-2013, 07:48 PM   #1
Electrical Stabilizer jacks won't work.
Hi...we just brought our new Rockwood ultra lite 2703 TT home today. We had a very thorough walk through and everything worked. However,
when we got home and tried to lower the electric jacks, nothing happened both front and rear. The tongue jack works and everything else works but can't seem to find the problem. I saw on another forum something about an inline fuse. Does anyone know anything about a fuse and if that might be the problem or any other ideas. We called the dealership and they couldn't help us over the phone, so it looks like we will be making another trip back there tomorrow unless we can discover the problem ourselves and fix it. Would appreciate any feedback you could give us.
2004 Dodge Ram 3500 4x4 diesel
2013 Rockwood 2703SS ultra lite TT
2703Rockwood is offline   Reply With Quote
Old 03-26-2013, 07:54 PM   #2
TURBS's Avatar
Have you checked the converter/fuse box for a blown fuse ?
Fuses by battery ?
Old 03-26-2013, 08:16 PM   #3
Thanks for the tip, Ron. We will try that first thing in the morning.
2013 Rockwood ultra lite 2703SS
Old 03-26-2013, 08:38 PM   #4
TURBS's Avatar
Also if you do find a blown fuse I'd suggest replacing it with a auto resetting circuit breaker of the same amps.
There also be a manual reseting curcuit breaker that you may have to reset by the battery or under the tounge of trailer.
Old 03-26-2013, 08:39 PM   #5
TURBS's Avatar
Replace this.
With this.
Old 03-26-2013, 08:41 PM   #6
TURBS's Avatar
You may have one of these that need reset.
Old 03-26-2013, 09:03 PM   #7
Denver, CO
garbonz's Avatar
Attachment 26486
Push the little button in the middle of the breaker. It should be by the battery.
2017 Fuse 23T
Old 03-26-2013, 09:10 PM   #8
Old car's Avatar
Same thing happened with our Windjammer when we brought it home. We replaced the fuse in the converter/fuse box and have not had an issue in two years since the initial replacement.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 03-26-2013, 10:08 PM   #9
Dave_Monica's Avatar
For reference, if you run the power stabilizers all the way to the mechanical stop and aren't fast at releasing the button, you'll blow the 15A fuse in the DC panel. I found out for myself...
Dave
Old 03-26-2013, 10:23 PM   #10
Dave
Dave, I don't think you are alone in that category or going in the stow mode either.
