Old 03-21-2014, 06:55 PM   #1
entrance door question on Rockwood 2502s
Still haven't got the new RV home yet. Was looking at pictures of it that I took when we bought it and noticed that it doesn't have a way to keep the enterance doors propped open like the Jayco I traded for it did. There was a thing on the door that you pushed into a slot on the outside of the body that kept the door from moving or closing. Is there a way to keep the doors open without them moving around?
gserve is offline   Reply With Quote
Old 03-21-2014, 10:47 PM   #2
Door
The door on your camper will have a little gas strut to hold it open.
bojangles is offline   Reply With Quote
Old 03-21-2014, 11:13 PM   #3
Plain Old Member
Hard to tell in a picture, but my guess is due to the awning location. When you open the front door, does it hit the front awning support? I don't mind the gas strut, should yours come with one, but definitely have to be careful. Depending on how well they're mounted, they can rip out of the door if you get too forceful with it. I removed the strut off of the few we had with them as it'd only let the door open 90į.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-21-2014, 11:24 PM   #4
NELA
Weezer's Avatar
One thing we miss on our new 5er is the gas struts on the door(s). I detest that little latch. One position...wide open or swinging in the wind.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 03-26-2014, 11:55 PM   #5
I think the gas struts are less effective in windy areas than the latch, which is why we had the dealer install a latch for the back door. I don't know that it would work with the front door because of the location of the awning support, so we'll just have to use that door in less windy weather, I guess.
catmom is offline   Reply With Quote
door, rockwood
