Old 10-06-2011, 01:23 AM   #1
Extension cord through slide opening
We are camping in New Hampshire and it is cold at night. In order to save propane, I am using an electric space heater, but one is not enough. I have read several threads where people have run an extension cord through the slide opening before the slide was fully opened to power a second heater. Just where is the cord placed- at a bottom corner or some other place? I have not looked to see if it's obvious yet, I will do that tomorrow in the daylight, but thought someone here might have the answer.
Thanks in advance for your help.
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
K_and_I is offline   Reply With Quote
Old 10-06-2011, 06:34 AM   #2
frankm's Avatar
Each slide out is different so yes you will have to look around it and see where's best. I run mine directly under it and comes out (in?) by the couch. I would avoid at all possible running it through the top of the slide though (too high a chance for water to infiltrate and deform the seal)
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-06-2011, 06:52 AM   #3
I run mine thru the front bottom corner then pull it up about a foot on the side gasket. use it for heat, toaster or fan in the summer. I use a three way adapter so I can use it for a couple of things at a time. Its an extra 20amps.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline   Reply With Quote
Old 10-06-2011, 07:09 AM   #4
Rugged Brown's Avatar
Why wouldn't you use a receptacle inside the camper.. Am I missing something here?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-06-2011, 07:13 AM   #5
We run the extra 20 AMP cord in due to the 30 AMP service being pretty well maxed out with normal factory installed appliances such as refer - water heater etc.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 10-06-2011, 07:38 AM   #6
frankm's Avatar
K, if you want to look into a more "permanent" way to add this extra power inside your camper read this thread: http://www.forestriverforums.com/for...ion-16938.html
Frank & Rita M
Old 10-06-2011, 08:59 AM   #7
Thanks to everyone for your responses. That is what is so great about this forum. Unfortunately, I cannot slide an extention cord between the slide and the gasket- not quite enough room. I think what I may do is to get another extension cord, cut off the female end, push it through between the slide and the gasket, then attach a repair female end on once it's in the camper. For the few times we need 2 heaters, this may be the solution.
Thanks again,
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
Old 10-06-2011, 10:10 AM   #8
frankm's Avatar
Thanks again,
You can always feed the cord through a window. Anyways it is recommended that to minimize condensation inside the camper, while running a heater or furnace, you leave a window or vent slightly open. Feed the cord, close the window tightly leaving an air gap and you should be good and comfy!
Frank & Rita M
Old 10-06-2011, 01:14 PM   #9
Have you actually tripped a breaker trying to run the 2nd heater or are you just assuming it will happen?
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 10-06-2011, 06:52 PM   #10
I tripped the breaker running both heaters at 750 watts. (trying to spread heat over the camper). It's supposed to get into the 20's tonight, so I went to a local Lowes and found a 14 ga extension cord with a thin male end. I was able to push that through from the inside out, so I'm sitting here with one heater working at 1500 watts and one at 750 so I can run bed warmer, laptop charger, cell phone charger, etc. Who said roughing it had to be so hard?
Thanks again for all of your help.
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
