Originally Posted by debandi
We have a Rockwood 2503s with the hang-on-the-side grill. Well, after a couple summers we need to replace it. Would like to use a standard propane grill but because of the push-on connection we are having a hard time finding a replacement.
My question is: Is there a hose that can be attached to the push-on connection with a normal propane gas grill connection on the other end?
or where do I get the connections?
I gave up on the original grill within one camping trip and replaced it with a Coleman RoadTrip LXE. I'm saving the original for sale with the camper when I replace it.
Here is a commercial option for the quick connect adapter. I have not used it and this is not an endorsement, but it does provide a one-stop option. The manufacturer apparently offers different version for different grills.
Torjik Converta-C
What I have done is adapted instructions in the YouTube linked below to attach a
Camco 59853 Propane Quick Connect to the brass connector of my Coleman Road Trip. The results are satisfactory and provides a versatile grill.
WARNING: at about the 1:50 mark the presenter says to remove the check valve.
Do NOT do that! To do so results in the potential of free-flowing propane if the threaded brass connector is not securely attached to the grill. Besides which, it's not necessary to remove it and doing so provides no benefit.
YouTube: Coleman LXE Grill to RV low pressure propane quick connect
I bought an extra
Coleman regulator assembly. I removed the regulator end and added a quick connect fitting. That requires some gas pipe dope and a fine-thread adapter between the metal tubing and the quick connect, but that's all. I got mine at a big box home store.
In addition, I bought a
Camco 57629 hose that has a quick connect on one end and a regulator with an Acme nut (standard propane tank adapter) on the other.
The end result is I can use my Road Trip with the small propane bottles as designed by the manufacturer. That's good for cookouts at the beach, etc. I can use it while trailer camping by pulling out the low-pressure hose from the wall of the trailer.
Finally, the hose and regulator serves as my backup outdoor kitchen should we suffer an extended power outage. I just set my 20# propane tank next to it and I'm good for days. I have had to use my grill and a propane camp stove for exactly that purpose back when Florida had 4 hurricanes in one summer. The Road Trip condenses that down to a single multi-purpose device for which the accessories are compact.
Because my approach ends up with an extra regulator, you may be able to use it in combination with other parts or an alternate hose to reduce the cost of parts purchased.
Edit: The YouTube below illustrates connecting the Torjik product. Importantly, it illustrates preserving the check valve in the brass connector.
