Old 06-29-2015, 12:35 PM   #1
Exterior Light Cover Removal Inquiry
I recently noticed that a bulb was burnt out on my exterior light (I believe the switch it is marked as either "ODS" or "DS" on my main control panel) on my 2012 Rockwood 8311SS Travel Trailer. In order to avoid any damage to the fixture, could someone please describe the correct cover removal process for me, as I do not want to damage the integrity of the seal. For your reference, there is a metal ring (sealed with silicone) that is secured with four screws to the side of the trailer and a plastic cover that fits inside this ring (the cover appears to have six depressions, but three of them have silicone in them, so I do not want to remove the sealant unless I absolutely have to...). Any insight would be greatly appreciated. Thank you in advance.
Brian
Brian Lahner is offline   Reply With Quote
Old 07-09-2015, 02:15 PM   #2
Brian, my Rockwood Roo uses all plastic fixtures on the outside that the lenses just pop out/off with a small slot head screwdriver, maybe you can take a picture of it and post it here so we all can see what it looks like and maybe someone will be able to help out.
Grez007 is offline   Reply With Quote
cover, exterior, light
