Old 04-26-2012, 05:42 PM   #1
Jimcam22's Avatar
Exterior Light on 8285WS
I have a blown bulb in the upper outside of my Fifth Wheel. I got my BIG ladder out to replace it but could not get the screws out. They look like a Torx head but none of my bits will fit. Upon closer look the head looks like it had 8 slots not the usual 6 in a Torx. Has anyone had to change the light, if so what did you use to get the screws out?
2011 Rockwood 8285WS
2012 F150 SuperCrew Ecoboost HD payload
Curt 20K Q5 Slider Hitch
Jimcam22 is offline   Reply With Quote
Old 04-26-2012, 05:57 PM   #2
TURBS's Avatar
will a #2 square drive not work ?
Old 04-26-2012, 07:36 PM   #3
Jimcam22's Avatar
No, everything in the trailer is a #2 square drive but not the outside lights. Go figure.
Old 04-26-2012, 08:04 PM   #4
If they have 8 slots, will a regular phillips not work? You can always get a Dremel and rework the phillips to fit.
Old 04-26-2012, 08:10 PM   #5
Rugged Brown's Avatar
Ran into the exact same problem. I used a slightly bigger square bit and hammered in in the head of the screw. I replaced the screws with stainless steel ones after. I done this to try and replace the rusty trim around the light but still couldn't get the trim off after removing the screws so I painted the trim. The lens is also secured with 4 screws that I think are phillips, but the screw holes will filled with caulking, and it was impossible to get them off. If you have luck, take pics and post with your solution.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 06-06-2012, 02:10 PM   #6
Jimcam22's Avatar
You were right. there are 4 phillips screws in the lens cover and they are filled with silicon caulking. I had to dig it out with a thin blade screwdriver and a pair of long nose pliers. You can see in the picture the 4 chunks of silicon that I dug out of the screw holes.
