10-18-2014, 01:11 PM
Exterior refrigerator. No on/off switch, no temp control
I can't find any switches or controls on my exterior refrigerator. It's 110 v only. Can't even get to the plug to unplug it unless I go inside and pull a drawer. Am I missing something?
10-18-2014, 01:20 PM
Plain Old Member
Nope. Pretty much all are like that. Once you kill shore power, it's off, and of course back on once you plug back up. Should be able to access the plug somewhere. Might be behind an access panel or door.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
10-18-2014, 01:21 PM
Plain Old Member
Once you find the plug, you can always install a small inverter to run it while not on shore power.
10-19-2014, 09:15 PM
I put an inline switch on the cord of my outside refrigerator. The cord is long enough so that I could pull enough cord out to install the switch.
10-23-2014, 12:06 PM
Plug should be right behind your bottom draw.
10-23-2014, 12:16 PM
Altho I find it hard to believe it's not entirely impossible that there's no on off temp switch.
I've not ever seen a fridge without one.
I've had two in my outside kitchen from forest river and they both had on / off temp switch.
Turbs
10-23-2014, 01:06 PM
The plug for the outside frig is behind the middle drawer on the inside side wall of the cabinet. To reach it, you have to remove the middle drawer which requires removing the screws from the drawer guldes, as the drawer is not removable otherwise. Not a user friendly setup, which is why I installed an inline switch on the power cord. This model frig does not have a temp control. Saves $$$$ that way.
10-23-2014, 01:17 PM
Turn the temp knob counter clock wise until you will feel a "click" at the 12 o'clock position. The fridge is now off.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
10-23-2014, 01:29 PM
What temp knob? I'm telling you, no matter what the manual shows and no matter what controls others may have, my fridge has nothing. It's nutz.
10-27-2014, 06:40 AM
, my outdoor frig has a knob located by the freezer top right hand. Turn left to tun off and right to on and colder setting.
Good luck
10-27-2014, 09:56 AM
AKA: 'tiredTeacher
Yeah, folks be like dat. You say there is no knob. They say turn the knob.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
10-28-2014, 04:25 PM
I did discover that the outside refrigerator has it's own it 15 amp breaker, so I guess technically I can no longer say it doesn't have an on/off switch!
10-28-2014, 05:05 PM
Be careful, that breaker labeled "Refrig" also controls about half of the outlets in your trailer.
10-28-2014, 05:44 PM
What is the brand name? Can you send a picture of the open fridge?
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
10-28-2014, 06:04 PM
Here's a generic picture of the outside. PD is all it says. I'll take a picture of the inside of mine and post it.
