Old 05-12-2012, 04:44 PM   #11
I believe it's a genesis or something like that, I can check if you would like and get the model # also. Sure made a world of difference the dealer said they have had problems with that brand that they were installing.
I'm glad it made the difference 12 setting is plenty enough sitting out side.
mrober is offline   Reply With Quote
Old 05-30-2012, 08:28 PM   #12
Paul & Sheri
pwb01's Avatar
When I turn on the interior speakers and set the volume it's impossible to bother the neighbors since with a reasonable interior volume the outside is almost off. Works well if I forget they're on outside. That could be the reason for it and I don't think if I set the volumn on the outside I'd need the inside on. Time will tell.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 05-30-2012, 08:31 PM   #13
Originally Posted by showtime0022 View Post
Install a speaker selector switch. A&B speaker switch
They come with an A, B & C switch. A=LR, B=BR, C=Outside
Old 07-04-2012, 01:57 AM   #14
Just what pwb01 said. Wife is in the kitchen listening to music on A speaker. I want to be outside and listen to C speaker. I cannot hear it very well as it is too low in volume. If I turn it up so I can hear outside the wife cannot stand the loud music inside. Is there a fix for this?
racerx is offline   Reply With Quote
Old 07-04-2012, 05:11 AM   #15
Arn
Arn
I'd assume it's a problem for the dealer. I set mine on 4 & can listen inside & out comfortably. 6 is too loud outside.
Arn
Arn is offline   Reply With Quote
Old 07-08-2012, 11:24 AM   #16
Road-King's Avatar
2012 3001w
Same problem here. Anyone found a fix?
Road-King is offline   Reply With Quote
Old 07-08-2012, 01:17 PM   #17
Bob Fields we need some assistance with this if you would.
Old 07-11-2012, 06:55 PM   #18
Road-King's Avatar
racerx, did you check you "B" speakers? On mine both "B' and "C", the volume is low compared to "A". I tried resetting the system, with no luck.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Old 07-11-2012, 07:06 PM   #19
doosterhouse's Avatar
I have the same issue. Except not only having lower volume on B and C speakers, my B speakers sometimes work and sometimes not so much. I have tried to reset like the Dealer said but to no avail. I think I am going to ask for a new radio this fall when it goes in for a few other things. I thought I heard that someone had theirs replaced and all speakers were same volume after new radio was installed.
2012 WindJammer 3006W
2013 Chevy Duramax 2500 HD LT Crew Cab Z71
2013 Chevy Suburan 2500 LT 4X2
Camping is my hobby
doosterhouse is offline   Reply With Quote
Old 07-11-2012, 07:45 PM   #20
I can use "a" & "b" no problem. Bear in mind that my hearing is a bit bad. Inside I set the volume around 6-8. Outside, I need to set it to about 10-12.
