Old 05-09-2012, 04:16 PM   #1
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Exterior Speakers
Hi All: I have a 2012 Windjammer 3001W. The exterior speakers are much lower than the interior speakers. If I have the interior set at a 4 for volume I need to turn off the interior and raise the volume to about 12-15 to be able to hear at a low level at the exterior. Is this normal for water proof speakers?? I have an appointment with the dealer at the end of May and want to get info on this before I go there. Thanks; Frank
Eaglelover is offline   Reply With Quote
Old 05-09-2012, 04:23 PM   #2
Malco's Avatar
The volume on our outside speakers is like that.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 05-09-2012, 04:44 PM   #3
Eaglelover's Avatar
That stinks, especially when you forget to lower the volume before you turn on the interior ones LOL
Old 05-09-2012, 05:03 PM   #4
Witch Doctor's Avatar
The speakers have a volume reducer connected in to protect them, I have the same problem. For some reason they are limited. How they do it is passed me, but they have told me that it can not be changed. To hear the outside I have to just listen to them other wise it's almost full volume inside. If you find out how to change that please post it.
Old 05-09-2012, 05:20 PM   #5
showtime0022's Avatar
Install a speaker selector switch. A&B speaker switch
showtime0022 is offline   Reply With Quote
Old 05-09-2012, 05:23 PM   #6
Malco's Avatar
If we are outside we usually turn the inside speakers off,otherwise it is way too loud inside when you go in.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 05-09-2012, 06:01 PM   #7
MilCop4523's Avatar
perhaps a design to ensure the neighbors are not blasted out of their trailer spot by you playing all that Techno music....
When you get them co-ordinated with a light show watch out...
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 05-09-2012, 06:10 PM   #8
Hoo Dad's Avatar
Mine are the same way. As stated earlier if you find a fix please post. I've just been dealing with it.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 05-12-2012, 08:51 AM   #9
I have windjammer 3008 2012, same problem with outside speakers
Being far to quite. After various discussions and persistence the problem has been resolved, they changed out the stereo. They are aware of this problem as it is common but they prefer to tell you it's normal for outside speakers. Not the case the replacement is 100 times better and now I have to turn it down instead of cranking to the max to hear it. No point in having to tell people to be quite to here it now I just turn it up. Very satisfied with the switch out.
mrober is offline   Reply With Quote
Old 05-12-2012, 09:52 AM   #10
Malco's Avatar
What did they put in for a new stereo?
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 05-12-2012, 04:44 PM   #11
I believe it's a genesis or something like that, I can check if you would like and get the model # also. Sure made a world of difference the dealer said they have had problems with that brand that they were installing.
I'm glad it made the difference 12 setting is plenty enough sitting out side.
Old 05-30-2012, 08:28 PM   #12
Paul & Sheri
pwb01's Avatar
When I turn on the interior speakers and set the volume it's impossible to bother the neighbors since with a reasonable interior volume the outside is almost off. Works well if I forget they're on outside. That could be the reason for it and I don't think if I set the volumn on the outside I'd need the inside on. Time will tell.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 05-30-2012, 08:31 PM   #13
They come with an A, B & C switch. A=LR, B=BR, C=Outside
Old 07-04-2012, 01:57 AM   #14
Just what pwb01 said. Wife is in the kitchen listening to music on A speaker. I want to be outside and listen to C speaker. I cannot hear it very well as it is too low in volume. If I turn it up so I can hear outside the wife cannot stand the loud music inside. Is there a fix for this?
racerx is offline   Reply With Quote
Old 07-04-2012, 05:11 AM   #15
Arn
Arn
I'd assume it's a problem for the dealer. I set mine on 4 & can listen inside & out comfortably. 6 is too loud outside.
Arn
Arn is offline   Reply With Quote
Old 07-08-2012, 11:24 AM   #16
Road-King's Avatar
2012 3001w
Same problem here. Anyone found a fix?
Road-King is offline   Reply With Quote
Old 07-08-2012, 01:17 PM   #17
Bob Fields we need some assistance with this if you would.
Old 07-11-2012, 06:55 PM   #18
Road-King's Avatar
racerx, did you check you "B" speakers? On mine both "B' and "C", the volume is low compared to "A". I tried resetting the system, with no luck.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Old 07-11-2012, 07:06 PM   #19
doosterhouse's Avatar
I have the same issue. Except not only having lower volume on B and C speakers, my B speakers sometimes work and sometimes not so much. I have tried to reset like the Dealer said but to no avail. I think I am going to ask for a new radio this fall when it goes in for a few other things. I thought I heard that someone had theirs replaced and all speakers were same volume after new radio was installed.
2012 WindJammer 3006W
2013 Chevy Duramax 2500 HD LT Crew Cab Z71
2013 Chevy Suburan 2500 LT 4X2
Camping is my hobby
doosterhouse is offline   Reply With Quote
Old 07-11-2012, 07:45 PM   #20
I can use "a" & "b" no problem. Bear in mind that my hearing is a bit bad. Inside I set the volume around 6-8. Outside, I need to set it to about 10-12.
