Old 01-27-2016, 12:16 PM   #11
mgoodwin's Avatar
I put a hold on the regular hitch and ordered the slider this morning. This video convinced me. Look at the 1:00 mark.
https://youtu.be/f2JjHwssJos
mgoodwin is offline   Reply With Quote
Old 01-27-2016, 12:17 PM   #12
mgoodwin's Avatar
Old 01-27-2016, 12:26 PM   #13
Pickin' & Campin'
In all ideal conditions, the Revolution will give you 90ļ clearance on a short bed truck (5.5) but as you referenced in the video at the 1:00 mark, if either the 5th wheel or the truck are on any kind of uneven surface, it will likely hit.
You may never use the slider (I have one and have not had to use it) but you will appreciate having it should you ever encounter a situation where you do.
Sliders are slightly heavier to load in and out of the truck bed but dents to the cab and busted glass can be expensive.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 01-27-2016, 12:47 PM   #14
Camper Bob
ok, thanks....it looks like i should not need the slider....that video is my model Flagstaff and a 5.5 ft bed.......?????
COBBOOK is offline   Reply With Quote
Old 01-27-2016, 12:52 PM   #15
mgoodwin's Avatar
From what I see in the video, if the truck and trailer are perfectly parallel you should be okay.
If on the other hand the front of the truck or the rear of the trailer are even slightly raised there will be contact.
I can't say I've ever been to a perfectly flat, level campsite.
I'm not taking any chances.
Old 01-27-2016, 01:07 PM   #16
TURBS's Avatar
F150, 5.5' bed - How close does your trailer get to your cab?
I know you wanted your comments based on a f150 and a Reese revolution which I have neither, however I have a shortbed gm and a 5th wheel with a slider and in 6 years towing this way I've never used the slider and this is the farthest I can turn with out engaging.
If you need more then that then there's something wrong.
In many cases a pull up and re back is needed.
A camping friend has towed a flagstaff 5er with a Reese revolution without a slider and f150 as well for 6 years and not had a problem.
Imo the whole point of the revolution is to not need a slider.
I think your wasting money.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-27-2016, 01:22 PM   #17
mgoodwin's Avatar
I hear what you're saying TURBS.
My street is pretty narrow and the back in is sharp but still, I may never need to go that tight. However in this case I'm lucky to work in the parts industry and the warehouse cost price difference is only a couple hundred bucks. For the peace of mind alone I think it's worth it. And, this is what sold me on the slider...
Old 01-27-2016, 01:27 PM   #18
TURBS's Avatar
It's your money do as you please!
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 01:27 PM   #19
wmtire's Avatar
The site team has merged two identical threads into this one. This should make it easier for everyone to follow and participate.
http://www.forestriverforums.com/for...ork&page=rules
  • Do not post the same discussion topic more than once or in several areas of the forum.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-27-2016, 04:03 PM   #20
Boso's Avatar
Close hitch
Get the slider because you will be situations where you will probably need, then it's too late. I wouldn't leave home without a super glide
Boso is offline   Reply With Quote
bed, f150, trailer
