Old 05-12-2014, 06:18 PM   #1
Fender skirt
I took my 2011 2604 TT out of storage last weekend. Found the fender skirt on the curb side cracked in the middle all the way thru. Any suggestions on finding a replacement? I tried to google it and found some websites but none of what I am finding match what's on my trailer.
reinbeauke is offline   Reply With Quote
Old 05-12-2014, 06:35 PM   #2
i found the same thing a few years ago when i had my 07 rockwood. i too searched online and found them quite expensive. i went to the dealer and inquired about factory replacements and they were 25 dollars. i was shocked. my dealer will also put parts ordered into trailers that are coming up from the factory and i did not even have to pay for the shipping to get them. try your dealer first.
05 gmc duramax cc sb
11 silverback 31b2
skidoonut is offline   Reply With Quote
Old 05-12-2014, 07:46 PM   #3
Really, I skipped the dealer cause I thought it would be crazy expensive. I will call them tomorrow. Thank you for the tip.
Old 05-17-2014, 07:41 AM   #4
KyDan's Avatar
My fender skirt(s) have also cracked in the narrow area over a tire.
I got my replacement from Forest River because my dealer is many
miles away. I figured the original had cracked because they used pointed
sheet metal screws and had not pre-drilled holes in the plastic skirt.
Mine had cracked right thru a screw hole.
I carefully drilled holes in the replacement skirt and caulked it in place.
It cracked within a year- just not directly thru a screw hole
I took a piece of copper sheet and made a patch which I placed in behind
the crack. I fastened it with aluminum pop rivets and it's not at all obvious.
I guess the plastic is cracking due to thermal expansion and contraction.
Mine cracked on the sunny side first but the shady side cracked a couple
years later. Of course you could use aluminum or stainless or
galvanized sheet metal for the patch. I just happened to have some
heavy copper flashing so that's what I used.
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
