Originally Posted by RBDTx
Thanks for the reply. I will try some more gentle persuasion. I wish my case/cover looked like the one in the video. Mine has two large, symmetrical halves that are separated by a vertical seam between them, a top/center switch plate with a thin gasket running around the top part of it that fits into an opening in each one of the halves, and a front light. This second generation does not have a top/bottom, and removing the screws on the light does almost nothing, at least without me trying some more persuasion.
That definitely looks different.
All I can offer is:
A: Look for seams that can be separated
B: Wait until the Sun has warmed the plastic some so there's more flex. Cold plastic is prone to cracking easier which is bad.
If you can move any panels that were secured by screws around try to figure where the hidden attachment points are. Sometimes manufacturers use hidden tabs with "hooks" on them and they just have to be "persuaded".
One thing to try if you can access the switch under rubber cover if there is a cover. Pull back waterproofing and spray some WD-40 in the switch, down the sides or wherever you can. Operate the switch and spray a little more.
If your problem is truly water, the WD-40 will displace it.
Stuff is great for getting water out of electrical parts. More than once an old car of mine has been restarted after a trip through a deep mud puddle or a pressure washing of he engine. WD-40 in the Distributor and cap worked magic.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
