Old 08-26-2015, 09:02 PM   #11
Some of you have mentioned plastic blocks? Where exactly are these found and what do they look like? Would anyone have pictures? I have a 8329ss with three slides that squeal terribly during the last foot or so of travel (last foot travelling out and first foot to foot and a half going back in). Lubrication has not helped. Seems like it has to do with shifting of balance point. I have not seen the blocks referred to by others but maybe I'm looking in the wrong place. Ant suggestions will be appreciated. Thanks.
2015 Rockwood 8329SS
2016 Ram Laramie 5.7L Hemi, 3.92 Axle ratio
Equalizer hitch
Breimert is offline   Reply With Quote
Old 08-26-2015, 09:06 PM   #12
B and B's Avatar
Lift up your carpet inside , the blocks are on the edge of the floor, white nylon or delran material.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-27-2015, 07:29 AM   #13
PhoneDude 8289's Avatar
My 8289WS was doing the same squealing as you describe. Below are pictures of the wear blocks I installed, this took care of my squealing problem. I ordered from FR , it came in one strip that I cut and drilled. The slide has to be all the way out, lift the lip of the slide carpet at either end. You will see weather you have them or not. My dinette / entertainment slide never had any installed, the kitchen / sofa slide had them.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
2013, fifth wheel, roo, slide, slide out, wheel
