Old 08-09-2015, 11:21 PM   #1
fifth wheel 8289 2013 dining room slide out
Binds In and out
Three times to camping world
adjust outside slide bracket last 1 Month then back to poping in and out
What could be the fix
Please help
Thanks Keith
2013 forest river rockwood modek 8289 fifthwheel diamond package
keithjsmith is offline   Reply With Quote
Old 08-10-2015, 05:33 AM   #2
Witch Doctor's Avatar
Originally Posted by keithjsmith View Post
Binds In and out
Please help
Thanks Keith
What do you mean by poping in and out? The Slide should not bind at all, It's still not adjusted right then,
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-10-2015, 06:38 AM   #3
vinmaker's Avatar
Is it jumping off a track? Are you seeing signs of rubbing and wear?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-10-2015, 06:50 AM   #4
B and B's Avatar
Hello. Just serviced at Goshen. Remove the plastic blocks inside under carpet flap. Our problem ended. Also grease the tracks with white lithium grease. You can do this all yourself.
Sent from Goshen at the Corner of Maple and Moo !
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-10-2015, 02:40 PM   #5
Remove the plastic blocks? Really? are you sure? WE have similar issue but Forest River told me directly to check them and make sure that they are sitting flat on the floor and not rolled over or even pulled loose.
JoeNanMinn is offline   Reply With Quote
Old 08-10-2015, 02:48 PM   #6
Its not a good Idea to use GREASE on your slide out guides and rams. The grease attracts dust and dirt and it causes theme to bind up after awhile. Better to use dri-slide or the lube designated for slide out systems. it goes on wet but dries to the touch quickly.
hillsdaletc is offline   Reply With Quote
Old 08-19-2015, 10:16 PM   #7
PhoneDude 8289's Avatar
I have seen where several FR techs have said to use the white lithium grease on the slide tracks and gear packs. Others have said to use a dry lube. I guess to each his own. If I were using the white lithium grease I would be sure to clean it all off yearly and lube with new grease. Doing the dry lube thing seems easier but I would think the tracks and packs should be cleaned periodically.
I added the blocks to my dining slide to stop all the screeching and squeaking when moving the slide in and out, they were missing. Nice and quiet now, I guess every unit is different.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 08-19-2015, 10:43 PM   #8
PhoneDude's post several weeks ago regarding the slide blocks sent me out to check mine. I found none on any of my 3 slides! While at Goshen I had a supervisor from one of the assembly plants in my TT discussing repairs. I showed him under each carpet overlap that my blocks were missing. He showed me that there never had been any and advised that my unit did not need them. Why? was my reply. His answer was that they are only necessary on heavier slides such as full wall kitchen types.
I have a 12' slide with fireplace, dining table/4 chairs and entertainment system. A 10' slide with stove/oven, refrigerator and sleeper couch. Both have always worked fine, no dragging or straining, so......I suppose all slides do not need those blocks.
When they adjusted my bedroom slide they did lube the track and gears very well with a dry spray teflon, also spraying the bottom plastic liner on it liberally so it slides on its entry into the TT easily.
Brian, I would try the dry lube first but if that failed to work to my satisfaction I would use Lithium, knowing it would need to be removed, tracks cleaned and reapplied at some interval.
Travel safe
Max
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
Old 08-20-2015, 01:50 PM   #9
B and B's Avatar
I used standard tacky grease year one. Cleaned off and used lithium as you have suggested Max. The Rockwood techs said anything really works but taking time to clean annually or when dirty is paramount. I also clean and grease the hitch a couple times a year. Amazing how nicely it hitches up when lubed.
Old 08-21-2015, 05:42 PM   #10
My hitch would never have worked very well, had I not taken it apart and buffed the heat scale off the pivot pin. Surely, mine missed a process to remove that before assembly.
robertew is offline   Reply With Quote
2013, fifth wheel, roo, slide, slide out, wheel
