Old 05-07-2012, 04:41 PM   #1
DAISY BOYKIN's Avatar
Fifth wheel king pin hitch
I have a problem with my frame for the king pin hitch I believe?? In the two picture of the problem on the 8258WS trim. I have tighten the trim several times, but they keep working loose. As you can see in the pictures
the caulking keeps separating from the trim. The door side of the Fifth wheel is worse. The trim moves down as much as a 1/4".
Has any one had the same problem? It is still under warranty, will be contacting Forest River about the problem tomorrow. Just got back off a two week trip to Charleston and Savanna when I noticed once again the trim has worked loose.
Name:	Caulk seam 001.jpg
ID:	13370   Click image for larger version
Name:	Caulk seam 002.jpg
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-07-2012, 05:30 PM   #2
TURBS's Avatar
imo this does not like like its going to end well .
almost seems that the frame is stressing and or cracked allowing your seems to open up.
Old 05-07-2012, 05:49 PM   #3
Crusader's Avatar
Looks like it could be a water leak. I had the same happen to me, but only one side. Had a small leak up near the roof and was tracking down the outside corner molding.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 05-09-2012, 08:12 AM   #4
fixit's Avatar
Mine is doing the same thing both sides let me know what you find out Thanks George
fixit is offline   Reply With Quote
Old 05-09-2012, 08:15 AM   #5
alageezer's Avatar
Mine did that when I first got it. Didn't think much about it, just recaulked and it hasn't done anything since.
2012 Signature 8285WS
2010 Ram 2500 w/Cummins
alageezer is offline   Reply With Quote
Old 05-09-2012, 08:15 AM   #6
Herk7769's Avatar
I caulked mine at the beginning of the season for the same reason.
Been dreading yanking the aero cap to take a peek.
HAM CALLSIGN - KC3FFW
Old 05-09-2012, 08:41 PM   #7
I had this same issue with my last trailer (8261SS). Dealer tried to close the gap by putting screws up though the weatherstrip into the wall. Didnt work. Ended up taking it on trade for a new trailer last year. Now we have a 8281SS. unfortunately it seems to be doing the same thing! The gap closes when the weight is on the hitch. I have noticed that there is some creaking and groaning when taking the weight off the hitch. Don't know if this is normal as both trailers have done it.
8261ss is offline   Reply With Quote
