Old 03-20-2016, 05:20 PM   #11
Bae
Bae's Avatar
Thanks all. I checked it and it is dual purpose. I will try the furnace next time we are at home and its cold. If i use the manufacture date of the trailer, I have until October for 60 month replacement. Where is the best place to buy a replacement? Amazon they are $80-$100 for a replacement.
2014 Silverado, 2012 2306 Mini Lite
13 nights planned so far in Michigan 2017
Bae is offline   Reply With Quote
Old 03-20-2016, 05:57 PM   #12
Get a sewer hose support. Those rocks will put a hole in the hose.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-21-2016, 06:28 AM   #13
53flattie's Avatar
Originally Posted by youroo View Post
It is "Recommend" to "NOT' use the FW Hose on the "Sewer Flush"! Youroo!! US flag on the 2nd line again?
I do. It only screws into the outside of the camper. It doesn't physically go inside the black tank or anything. Am I missing something?
2015 Rockwood 2306
2015 Tundra CrewMax
53flattie is online now   Reply With Quote
Old 03-21-2016, 07:11 AM   #14
it is always recommended that you use two different hoses, and NEVER swap out the two,....the spray head in the black tank has/at least should have a "back flow prevent-er" valve and it can fail, so the possibly of bacteria working it's way to that black tank flushing connection on the side of trailer is very real,.......
fella10 is offline   Reply With Quote
Old 03-21-2016, 07:27 AM   #15
53flattie's Avatar
The water jets are spraying *into* the tank and there's a backflow preventer. The bacteria would have to be strong enough to swim upstream against the force of the freshwater. I suppose it's possible, but so are car crashes. In both cases, it's an acceptable risk for me. But to each his own.
2015 Rockwood 2306
2015 Tundra CrewMax
Old 03-21-2016, 07:34 AM   #16
KnP
I noticed a bit of backpressure from the tank. Very possible is the reminder pressure from the internal hoses that connects to the spray nozzles. I solved the problem with a valve. If you see my pics. The silver connector is an On/Off valve with a quick disconnect. Once you shut the water off at that point, disconnect the quick coupling, no backflush. Just wait few seconds for the internal build up pressure to die. Might add a check valve as an added protection.
If is a free flow, I see the point.
The quick disconnect, not only makes it a breeze to hook and unhook with full pressure on the hose, but saves me the wear and tear from screwing/unscrewing. Now I need to find a suitable cap for the connector end.
2016 Rockwood 2306
2016 Chevy Colorado Z82 / 2009 Pontiac G8 GT
KnP is offline   Reply With Quote
Old 03-21-2016, 08:01 AM   #17
Originally Posted by 53flattie View Post
The water jets are spraying *into* the tank and there's a backflow preventer. ....... it's an acceptable risk for me. But to each his own.
in a perfect world, back flow preventers would never fail, but they do in this im-perfect world,.....and when they do they are "open"(not stopping the backward flow), ......so, when/if it fails the bacteria CAN make its way from the tank, by way of the flushing hose, to that outside connection and will be there waiting to say "hello" to any hose that you use, the next time you connect to it,...that's the reason it is advised to use two different hoses,....but you are very right.......to each his own
Old 03-21-2016, 08:38 AM   #18
Pickin' & Campin'
If you have a hydraulic hose sales place in your area, check out their assortment of dust caps for hydraulic quick connects. They usually have a nice assortment of sizes and one of them would most likely fit.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-21-2016, 08:55 AM   #19
hammer55's Avatar
seeing where you live it would be like camping all year long, drove through there last september, very beautiful
Originally Posted by Papa-t View Post
That reminds me of 19 years ago when we purchased our first camper. My wife, myself and daughter driveway camped at the house. Good times. Good times.
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-21-2016, 12:13 PM   #20
mike.t's Avatar
Great idea! Make sure everything works before you leave. Every dealer/salesmen/factory/rv forum should have this on a 1st to do list.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
2306, camping
