Old 09-05-2011, 08:01 PM   #11
just got our 2012 3001w went 1471 miles from dallas to goshen & picked it up, met our daughter in ny city for shopping trip, but cut short due to hurricaiine so left & went to gettysburg until it passed then back to liberty harbor they caught a flight out of newark we left for washington dc & slowly back to dallas following in the cool air . my question is when you park on a level surface & put the stabilizer jacks down, the trailer is level from side to side & front to back. when you extend your slideouts the trailer tips to the side 1 & 1/2 inch to the slide side , so the trailer is unlevel & you sleep with your head lower than your feet. if you set your wheels on a block to compensate the slideout on the bedroom still dropps 1&1/2 inch any ideas??
nordyke is offline   Reply With Quote
Old 09-05-2011, 11:54 PM   #12
JoeR's Avatar
Mine does the same thing. I learned to set it half a bubble high on that side and it levels out when you extend the slides.
JR
JoeR is offline   Reply With Quote
Old 09-06-2011, 07:14 AM   #13
Wanna Be Camper
SaskCampers's Avatar
I leave ours slightly slide side low to keep any rain away from the slide seals.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 09-06-2011, 09:18 AM   #14
Koodog's Avatar
Joe,
Thanks for the reply about the TV. Yep...I also noticed the price drop at GORV in Evans. Looks like they lost 2 customers on that unit. As far as I know its still on the lot and its a 2011 model.
Just got back from 2 weeks in the boonies with my 8317 SS. Everything worked well. I managed to mess up my rig a bit on a big rock I didn't see. Trashed the stairs and a bit of the under carriage panel. Guess I know what I'll be doing this winter. Oh well, gives me a reason to drop the underside paneling and take a look around.
Walt-N-Terry Sanford
03 Dodge Ram 2500 Diesel
08 Rockwood 8317
Koodog is offline   Reply With Quote
Old 09-06-2011, 10:29 AM   #15
so you just block up the whwwls on that side & take a readong on the level? & where do you mount the level
Old 09-06-2011, 10:42 PM   #16
What kind of miles per gallon did you get with the tundra? We have the 2011 & tow with 2011 Dodge 1/2 ton with 5.7 & get 8mpg
Elmer Swan is offline   Reply With Quote
Old 09-07-2011, 07:30 AM   #17
Grumpy Old Member
ChrisZazzara's Avatar
Just for an interesting comparison, I tow with a 2010 Dodge RAM 1500 5.7 also and with the Tow/Haul mode selected I've never averaged less than 10 mpg for a long trip. Last night I moved my TT about 50 miles from my seasonal spot to the dealer for a little warranty work before a trip next week. Averaged 10.7 mpg from campground to dealer lot. Mostly highway travel, averaging about 60.
And btw, I too block the slide side a little high to offset the lean that the suspension apparently allows when parked with the slides out.
Just some thoughts to share...
Chris Zazzara
2012 Windjammer 2008w
2010 Dodge RAM 1500
Reese Dual Cam WDH
ChrisZazzara is offline   Reply With Quote
Old 09-07-2011, 09:38 AM   #18
mkollath's Avatar
ditto on rasing the opposite side a bit to accomdate the slide outs...thats we do..on the mileage, we get average 10.5 - 11.0 at 62 MPH, rpms at 1700 in tow mode...not climbing mountains with the TV but does well on flat...new TV is next
Mark and Connie
2008 3001W Windjammer
2005 Tahoe Z71, 5.3L
Equal-i-zer WD
mkollath is offline   Reply With Quote
Old 09-07-2011, 09:54 PM   #19
My Ram may get better when I get more miles on it. I only have 5000 miles on the speedo now plus I have a 3,21 rear end as I didn't have TT at time I bought the truck I'm useing Equal-i-zer WD as well I didn't think about raiseing the slide side have you noticed a diff. All so I've been towing at freeway speed Limit of 70 to 75
Old 09-08-2011, 09:53 AM   #20
Grumpy Old Member
70 to 75mph on tires that are just rated to 65? Hmm, I tow around 60, better for milage and safer if one of those cheap Chinese tires decides to fail.
Chris Zazzara
2010 Dodge RAM 1500
Reese Dual Cam WDH
