05-08-2016, 05:55 PM
#21
I have had satisfactory results using the EasyLift stands. One placed before the axles and one aft of the axles on the opposing side. With a sealed underbelly there aren't a lot of options. I also use the Camco version of the X chocks between the wheels. I made the blocks to fit the conforms of the frame rails and it places the jack screw axis at the center of the fabricated frame rail. The blocks are held captive on the jacks for ease of install. The one in the foreground sets between the slides and out of the way of the dump valves. After the slides are out and stabilizers are down, about 1 1/2 turns from point of contact with the frame made a noticeable difference. The stands don' t have the wobble like the scissors jacks
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
05-15-2016, 01:55 PM
#23
I've got a set of those on the way. Should be here Tuesday.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
05-15-2016, 03:47 PM
#24
Using my new set of xchocks and two valterra stabilizers this week in Navarre beach., FL. IMO, the combination has reduced bounce by at least 75%. I really feel that one more stabilizer on the opposite side will reduce most of what's left of the bounce. Very pleased.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
05-18-2016, 12:39 AM
#25
Some guy in back...
Hi--I like these jacks! Do you have a link? (Slick heads, too!}
ChateauV10
St. Charles, MO
Ex-SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
05-23-2016, 06:07 AM
#26
I don't have a link but, they are Camco EAZ-LIFT jack stands from Amazon. 3 position adjustable and with the screws out will go out to 30". The blocks were milled from a block of PVC
14K Equalizer
05-23-2016, 06:52 AM
#27
I started to buy some xchocks for my windjammer, even had them in my online shopping cart, but then read some reviews about them hurting the tires.
Anyone know anything about this?
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
05-23-2016, 07:05 AM
#28
Left Coast
Not a problem hurt'n tires...
Sent from my XT1585 using Tapatalk
05-23-2016, 07:06 AM
#29
Left Coast
05-23-2016, 07:14 AM
#30
Frog-Toberfest Organizer
Is the Ball Lock-Arm stabilizing Bar as good as the JT Strongarms? Just curious because the BAL are cheaper (more affordable).
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
05-23-2016, 07:31 AM
#31
Left Coast
Probably..,.there's JT's on here
05-23-2016, 10:10 AM
#32
Some guy in back...
Thanks for the details! Are the blocks held in with what look like two pins, side to side?
Also, what is the red cylinder thing mounted in the background of the one pic? Looks like it's parallel to the frame rails?
Cheers!
ChateauV10
St. Charles, MO
Ex-SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
05-23-2016, 10:20 AM
#33
Cheers!
The pins are nothing special, a couple 1/8" pieces of SS rod that were crushed on one end (in a vise) and pushed into the pvc with loctite to hold the jack screw top captive. There is a littile wiggle room in the diameter and depth to allow slight self alignment and a a cutback radii at the vertex of the vertical and horizontal planes that was added after the initial machining. The angle piece of plastic trim needs somewhere to go when you tighten the jack. It will move as the corrugated compresses. I don't think wood would be a good material, it will crack. The PVC finished is 2 x 6 x 3 1/2. Without access to a bridgeport, you can probably get er done with a router. For the PVC material, try McMaster Carr or Grainger. Do your math on the measurements to put the center of the 1 7/8 hole for the jack's pad at the center of your fabricated I-beam, if that's what you've got. Then your forces will be in line.
The red cylinder is nothing special either... my TV is parked next to the TT. It's the rocker panel on my red truck!
14K Equalizer
05-30-2016, 09:26 AM
#34
Bounce in new WJ 3029
Hi all, I've owned a 2017 WJ 3029 for about 3 weeks, not been out in it yet. Love the layout inside but there is lots of bounce inside with electric stabilizers out. Our old TT was much more solid. I've been looking at the BAL adjustable bars (instead of JT Strong Arms) but worried about where to install them on front due to the lowered frame of TT and the V- shape of frame. On rear looks easy enough.
Can someone tell me where to attach the bars on front, and also, will the installation of the BAL bars be effective? Thanks!
06-01-2016, 04:53 AM
#35
Originally Posted by bob caldwell
In a month from now, OC and I will be adding an electric stabilizer in that location for that very purpose...also, you can add a step support..
How did this turn out? Any pictures?
06-01-2016, 08:26 AM
#36
Left Coast
Works great
