Old 04-14-2016, 07:44 PM   #1
Fixed RV bounce!
Everytime someone went in or out of our RV or turned over in their bunk the entire RV would shake. We have a Rockwood 8327SS. I bought 2 heavy duty jacks and mounted them right in front of the front axle of the trailer. This is amazing the difference!
Name:	ImageUploadedByForest River Forums1460681081.139911.jpg
firedaniel is offline   Reply With Quote
Old 04-14-2016, 08:38 PM   #2
Left Coast
In a month from now, OC and I will be adding an electric stabilizer in that location for that very purpose...also, you can add a step support..
Old 04-14-2016, 08:54 PM   #3
crunchman12001's Avatar
Attachment 104933
Thanks for sharing. I have the same issue.
I have a seasonal site and have jack stands that I will try this year. I should be able to raise the tongue a bit and lower back down on the jack stands. I still might have to buy the xchocks though if the stands do not work.
2015 F-250 FX4
Old 04-14-2016, 09:02 PM   #4
SeaDog's Avatar
I added the steady fast system to my TT and it is solid as a rock, I also got a cameo step stabilized however I don't like the way the step rocks on the stabilizer. it does stop the TT movement. If my trailer were longer I would consider the mod you did nice job
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-14-2016, 09:38 PM   #5
I also have steadyfast but still had the bounce from the middle of the trailer. Steadyfast worked well with my 28' trailer. This one at 35' still had a bounce from the suspension. It's rock solid with this in the middle.
Old 05-02-2016, 08:05 PM   #6
I was removing stickers from the wheels while my wife was moving around in the trailer and I noticed a lot of movement at the wheels, with stabilizers down. (Concrete driveway) I figured I'd try the Camco wheel stops. They cut trailer movement by 80 or 90%.
Also added two folding step supports.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 05-02-2016, 08:10 PM   #7
burch42's Avatar
i added one on each side in the same area. made a world of differenceClick image for larger version
Name:	ImageUploadedByForest River Forums1462237849.630038.jpg
burch42 is offline   Reply With Quote
Old 05-02-2016, 08:11 PM   #8
Cyber Phrenologist
Radio's Avatar
Those things are wonderful! And if you don't have them try putting lego levelers or just wood blocks under the steps. Some one coming up the steps would knock you out of bed before we thought about stabilizing the entry steps.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-02-2016, 08:26 PM   #9
SeaDog's Avatar
Check into X-chocks they limit the movement. I also added steady fast and not my TT is rock solid.
Retired Navy
Old 05-02-2016, 09:53 PM   #10
dcheatwood's Avatar
Good job. I've been considering that myself.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
