Old 04-11-2015, 08:52 PM   #11
WFD
Don't mix the water filter with the black water flush system....they are not related!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-11-2015, 09:29 PM   #12
Klbrown53's Avatar
Flushing out 8289ws tanks
One of the first things that I bought was a clear plastic elbow for my sewer hose. That way when I flush my black water tank using that outside hose connection I can actually see when nothing but clear water is coming out. I will sometimes close the black water valve with the flush hose running momentarily to get just a little water back in the tank and then reopen. That helps me know that I have most everything out of the black water tank. Disclaimer......DO NOT CLOSE THAT VALVE WITH THE WATER RUNNING AND LET IT RUN VERY LONG.
I would love to hear other folks opinions of doing this. It is just a way I figured out to get a little more of the crud out of the tank. Most of the time after flushing for a bit the culprit seems to be left over paper.
Ken
Klbrown53 is offline   Reply With Quote
Old 04-11-2015, 09:32 PM   #13
B and B's Avatar
I do the same, I don't have a clear elbow, just unhook and check the outflow when it slows down.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-11-2015, 09:39 PM   #14
Klbrown53's Avatar
Clear elbow,
One of the best and least expensive accessories I have bought.
Old 04-11-2015, 09:48 PM   #15
Originally Posted by Klbrown53 View Post
Clear elbow, One of the best and least expensive accessories I have bought.
X2, semi permanently attached mine with sheet metal screws.
Name:	Sewer Clear elbow.JPG
Old 04-11-2015, 09:53 PM   #16
Klbrown53's Avatar
OldCoot,
You have some really good ideals.
I like it.......
Ken
Old 04-11-2015, 10:21 PM   #17
OldCoot,
You have some really good ideas. I like it... Ken
I also added a valve ahead of the elbow for insurance.
Old 04-12-2015, 02:59 PM   #18
5er_tom's Avatar
Our black tank got plugged with who knows what. Anyway, after lots of failed attempts to get it to drain, I closed the dump valve and used the clean out input to fill the tank. The wife was inside watching and yelled when water began to back up into the toilet. It took many minutes for it to fill. Then, after checking to be 100% sure all sewer hose connections were tight, I opened the drain valve. Whatever the problem had been got washed out the drain valve. It was an unnerving experience but I was desperate. It was the only way I could think of to get it flushed out.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 04-12-2015, 03:18 PM   #19
bubbles's Avatar
Actually, other than letting it back up into the toilet that is the way the black tank is supposed to be cleaned out. Should fill till full indicator (light) annunciates or water reaches to the bottom of toilet input to tank and then open dump valve. Will never have a light issue and the tank will not require any of those cleanout procedures. The tank will not fill up immediately, mine takes about 20 minutes. There are many who think this is ridiculous but just google for black tank cleanout procedures. There are also many urban legends of overflows and such. Just don't walk away, as you normally wouldn't anyway, while dumping.
Old 04-12-2015, 06:11 PM   #20
Klbrown53's Avatar
I have not tried that bubbles but certainly has merit.
tank
