Old 08-22-2012, 09:18 AM   #1
Hoo Dad's Avatar
For you electrical guys in the know
My light over the kitchen stove burned out. It is a wedge type light rated at 10 watts maximum. Can I replace with a 12.8 volt automotive light? Will the light be dimmer or brighter? Why are some bulbs 12.0 volts and others 12.8 volts? I have researched and can't find an answer. Auto store employee didn't have answer either.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 08-22-2012, 09:20 AM   #2
Simply a bulb rating from the manufacturer. Get any automotive bulb with the correct base and put it in.
Old 08-22-2012, 09:42 AM   #3
wmtire's Avatar
12.8 volts is the average that a fully charged 12 volt battery has. Here is an explanation of different types of bulbs, bases, and stuff. Another one for Herk's/Lou's ever expanding library.
Miniature bulb, Miniature Bulbs, Miniature Lamp, Miniature Lamps, P13.5S, miniature flange base, Single Contact Bayonet Base, Double Contact Bayonet Base, Candelabra screw base, Festoon 8mm, SV7mm Base, Festoon 10mm, SV8.5mm Base, 2 pin base, miniatu
This is an excerpt from the link that helps explain it some:
Next in importance is voltage identification. Voltage is electrical potential while amperage is the flow or current of that electrical potential. Typically voltage and amperage is stamped on the base of the bulb. Wattage is calculated by multiplying voltage and amperage. If your bulb is stamped with 12v and .1A you may multiply 12*.1=1.2 Watts.
There is some margin of error with voltage but ideally it should be as exact as possible. It is always better to order a slightly higher voltage than a slightly lower voltage. Typically bulbs are designed for a slightly higher voltage than the anticipated power source. For example, household bulbs are generally rated at 120 or 130 volts while the voltage coming out of your wall socket is only 110 Volts. A 130 volt bulb will have a heavier filament than a 110 volt bulb and will last much longer. Similarly automobiles have a 12 volt battery yet many automotive bulbs are rated at 12.8 Volts.
In summary if you cannot find a bulb with the exact voltage stamped on your bulb you will be OK with a bulb with a slightly different voltage. A bulb rated with a slightly higher voltage will not be quite as bright but last longer or a bulb with a slightly lower rated voltage will burn brighter but not last as long. Using too low of a voltage bulb i.e. a 24 volt bulb in a 110 volt lamp will result in the bulb burning out almost instantly while using a 120 volt bulb in a 24 volt lamp will result in a very, very dim bulb that will last a very, very long time.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-23-2012, 06:38 PM   #4
Paul & Sheri
pwb01's Avatar
You can find several different wedge type bulbs in the auto store. For example, I have 7 watt bulbs in the bathroom and a couple of yellow ones where less light is required. One alternative to expensive LED's is to find low watt auto types and use them where less light is needed.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 08-23-2012, 07:51 PM   #5
You can also use the landscaping lights from Lowes/HD, etc. All sorts of different wattages.
Old 08-30-2012, 02:56 PM   #6
sawdusterz
I suggest the replacement LED currently on sale at campers world which for 10 bucks give you 50,000 hours and according to the light guys supply equivalent lumins?
Larry Olver
lARRY oLVER is offline   Reply With Quote
Old 08-30-2012, 03:48 PM   #7
Herk7769's Avatar
Some alternate ways of approaching this (and MUCH less expensive).
Car 48 LED Dome Festoon Interior Bulb Map Light with T10 adapter & Festoon Base | eBay
2x Red 194 168 T10 SMD 5 LED Car Lighting Wedge Light | eBay
White 36 LED Car Interior Dome Map Light Bulb T10 Adapt | eBay
LED Replacement Lights
LED 12 volt lighting: Long term results
ID:	18907   Click image for larger version
ID:	18908   Click image for larger version
ID:	18909   Click image for larger version
Name:	Key West 2011 012.jpg
ID:	18910   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 08-30-2012, 04:55 PM   #8
spierce617's Avatar
Herk, Have you found any with the older BA15s conversion plugs? We have a 2005 Cherokee Lite 28a that takes that style.
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 08-30-2012, 06:44 PM   #9
Herk7769's Avatar
That same vendor also has the "tail light" socket bulbs.
So does:
12 Volt 1142 (BA15D) 18 LED Tower bulbs
