Old 01-23-2014, 07:48 PM   #1
Owner/Operator
RodeoGeorge's Avatar
Forum Search Comes Through
Found when we were last out with the RV that the Range Hood Fan did not operate. I finally got around to checking it out.
First though that because the outside vent flap was not open, the motor circuit had some sort of interrupt or interlock. Couldn't figure out how to open the outside flap, BUT a search of the forum solved that. Thanks to all that posted in that thread. As others, I was leary of applying too much pressure on the flap clips, but after reading the posts knew that it might take considerable effort.
Anyway, flap open, and still no fan operation. Isolated the problem to an open SEFUSE (99 degrees C) that is taped to the side of the motor on the ground line. This thermal fuse opens to prevent the motor from overheating.
Sent an email to Ventline asking for a replacement, but doubt that they will send one since they actually come with the motor. $2 on eBay, and I'll be back in business.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 01-25-2014, 07:26 AM   #2
AKA: 'tiredTeacher
awellis3's Avatar
Yeah, what's up with that? I've had to take a screw driver and pry the clips open.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 01-25-2014, 12:10 PM   #3
Owner/Operator
I received a reply from Ventline regarding the defective (open circuit) SEFUSE that is taped to the motor. As I mentioned earlier, it is a safety device to prevent motor overheating.
Ventline states that the SEFUSE is only required on RVs that are sold in Canada, as it is a Canadian RV spec requirement. They told me that I could order a replacement motor without the SEFUSE and install it.
My guess is that Rockwood just uses that model Range Hood on all their RVs so that if they are shipped to Canada they are covered.
Why would I order a new motor when I can just bypass the SEFUSE? I've checked the motor, the current draw is within specs, and it runs cool.
Bottom line. I ordered a replacement SEFUSE (SF96E) on eBay for $2, and will install that when it arrives next week.
RodeoGeorge
