Old 02-23-2016, 06:18 AM   #11
A lot of the strength is in the laminated floor assembly.
I didn't realize you meant the full height cross members, but I have seen where they use one of those for one side of the tank support. I guess in that case all you can do is treat it and re coat it unless you wanted to get into replacing those. Believe it or not they sell them. I know people who have added extra cross members when the floor went spongy.
I think you would need some major rust on those before worrying about it.
Mr Havercamp is offline   Reply With Quote
Old 02-23-2016, 06:31 AM   #12
I can easily coat the part of the cross members I can see but the side toward the tank I can't. I really don't want to get into dropping the tanks. I had forgotten that those cross members support the already spongy floor so cutting them out isn't going to work out.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 02-23-2016, 07:23 AM   #13
RSchleder's Avatar
Rustolem makes a product called Rust Reform that will convert rust to an inert material that will never rust again. Check it out, I've used it for years and it's never failed me.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 02-23-2016, 07:25 AM   #14
I'll definitely check it out, thanks. Is it something that sprays on? Do you have to paint over it?
2013 Rockwood 2109S
Old 02-23-2016, 07:49 AM   #15
KyDan's Avatar
Google is your friend-- Rustoleum Rust Reformer is available in brush on and
spray can. The Rustoleum site says WallyWorld carries it as well as AutoZone and probably your friendly neighborhood hardware store.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-23-2016, 07:52 AM   #16
I know Google is my friend but I like to hear what real people have used and how they applied it. He said he had good luck with no more rust so I'd like to replicate his application procedure.
2013 Rockwood 2109S
Old 02-23-2016, 08:00 AM   #17
Originally Posted by GearHd6 View Post
I definitely have to do something with it. Has that issue ever been seen before? It's like the factory paint never stuck. There is clean metal under some of it.
Yep, happens all the time. Like the other poster said, prep it and re-paint it with the required materials. You need to appreciate how construction of an RV happens and say, the assembly line at an automobile plant. Not even close in mfg processes. The reason are many, unit production, plant and equipment expense, the list is long.
Old 02-23-2016, 10:00 AM   #18
The list may be long but I do not see how any of it justifies a frame that rusts or has the coating peel away in sheets on a 3 or 4 yr old trailer. There is such a thing as preventative maintenance but I don't think the OP's issues fall under that category. I have seen some of these frames rusted to the point you could not tell they were ever painted and they were not much over 2 yrs old. Its nothing more than piss poor manufacturing and buying frames from the lowest irresponsible bidder. You can try but you can't sugar coat it, although sugar may make a better coating than what they are using.
Old 02-23-2016, 10:10 AM   #19
Now mind you, that is not the only spot on this frame doing that. You can tap your finger all over and you can hear the paint is popped off the frame. Just pick a little and it'll all peel off like that picture I posted. I emailed Forest River about it yesterday and they got back to me in about an hour saying they were sorry my frame was doing that but the frame is only warrantied for 1 year so I'm out of luck.
2013 Rockwood 2109S
Old 02-23-2016, 10:16 AM   #20
GearHd6 any way you can get under there with a high PSI pressure washer and peel all the paint off and respray with a good anti-rust paint?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
frame
