Old 02-23-2016, 05:55 PM   #31
Originally Posted by GearHd6 View Post
They'd be better off just to put the paint in their spray gun and blow it all into the trash can. At least then when I buy the trailer I know to come home and prep it correctly then put the proper paint on it. That way I have no expectations from Forest River.
Yep if I ever do get my Roo, which seems to get further away daily, I have already planned to go coo coo for coatings. Maybe I'll get lucky like my 2013 Keystone was. It didn't rust much and was an LCI frame, but someone else with the same model but a 2012 rusted to high heaven. Who knows when they change materials or means and methods?
Maybe the prep guy is huffing the paint before they spray it?
Mr Havercamp is offline   Reply With Quote
Old 02-23-2016, 06:38 PM   #32
I purchased my X-Lite used in 2014 and last summer I decided that it was time to start refinishing the frame due to the same rusting, bubbling, flaking issues that you all have noted. For test purposes, I did the A-frame from the front cross member to the hitch. I used a wire brush cup on an angle grinder and removed as much of the loose paint and rust as possible on all four sides including the battery support tray, propane tank tray and WD hitch brackets. I then primed with a rust converter (I believe it was a Rust Check product) and after washing with water and allowing to dry, brushed on two coats of semi-gloss black Tremclad allowing a day to dry between each coat. I was very pleased with the results last summer and when I checked it a few weeks ago, it still looks great. My plan is to continue with the remaining frame this summer now that I know my methodology works. And yes, I have a LCI frame FWIW.
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
Ontherock is offline   Reply With Quote
Old 02-23-2016, 07:05 PM   #33
I wish Tremclad was available in the US.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
frame
