Old 05-10-2016, 11:09 AM   #21
Canadiancrew's Avatar
Great topic. I am going to have a look at doing this the next time the trailer is in the driveway.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 05-15-2016, 06:26 PM   #22
My wife and I did the mid by removing one screw, sliding window over and removing the plastic piece. 10 minutes to do all of the Windows
Linc
missing_link is offline   Reply With Quote
Old 05-16-2016, 01:10 PM   #23
fil564's Avatar
Had my rollers pop out of the track last year on a window, mine has a window above so I could not slide it over. Found a video on you tube, drill out the rivet with a 3/16" bit and replace the rivets with a 10-24 1/2" long SS bolt with a nylon locking nut. Did all the windows before the season so it is an easy fix if it happens again.
Phil
2012 Ford F-350 Lariat Crew Cab 6.2L FlexFuel
2014 Rockwood Windjammer 3008W
fil564 is offline   Reply With Quote
Old 08-26-2016, 09:39 PM   #24
Originally Posted by GVJeeper View Post
Wow..thanks! I just watched a YouTube on rivets and it looked easy enough. Thanks so much for your help!!!!
Do you have a link to the YouTube video showing how to get the window to go out further.. ? I don't see a plastic spacer on my Rockwood Mini Lite 2506S model year 2017..
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S
clintbonnie73 is offline   Reply With Quote
Old 08-27-2016, 11:51 AM   #25
Nurek's Avatar
I like how users here said they watched a YT vid, but couldn't be bothered to post a link.
Why even bother posting that you watched the vid in the first place??? :S
I did find this
Nurek is offline   Reply With Quote
Old 08-27-2016, 01:08 PM   #26
I did find this
Clint...
Old 08-27-2016, 03:23 PM   #27
gooiebob's Avatar
Our 2703 has a plastic spacer between the arms on the bottom of the window. Remove the screw at the top of the window slide it over to release one arm and there should be a plastic spacer that fits between the rollers. cut it to fit.
ours is a 2013 maybe they changed it after our windows or put in.
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is online now   Reply With Quote
