Old 09-20-2016, 04:53 PM   #11
window parts
Check out this webpage. They are the suppliers of frameless windows to FR. Many parts listed.
Page Title -Kinro windows and replacement parts
RStormC is offline   Reply With Quote
Old 09-20-2016, 04:57 PM   #12
question for metalsideup
Metalsideup
Did the end pieces that go into the window channel come with the crank assembly? I don't want to spend the money on the part and not have the only part that I really need not be included.
Old 09-20-2016, 05:56 PM   #13
The arm assembly I received was all 1-piece. It consisted of the turn shaft and the 2 articulating arms with the little rollers on the end. It had everything needed except the plastic t-handle and the rivets. I opted to use tiny stainless bolts with nyloc nuts just in case a disassembly was necessary. To reiterate, buying a new mechanism did NOT resolve my windowing coming open while moving.
metalsideup is offline   Reply With Quote
Old 09-20-2016, 09:07 PM   #14
Thank you
I only need the little rollers but may have to buy the entire assembly. I am hoping that part number RS07014 LINK ARM from Kimro will solve my problem without buying the entire assembly. At least that is better than an entire window. I think that I am going to drill a small hole in each end of the channel and install a simple door hook or spring to ensure that it stays closed. Not sure how I am going to work around the screen. Unfortunately, the other parts are necessary to make the window function properly
Old 09-21-2016, 12:23 AM   #15
RStormC, I will search my garage and see if I kept my original arm assembly. If so, I will pm you and send it your way.
1809s, frame, rockwood
